Rutoken ЭЦП 3.0
shamaaan
Rutoken ЭЦП 3.0
Сообщение shamaaan »
Доброго времени суток, подскажите поддерживает ли wtware токены Rutokenт ЭЦП 3.0?
при подключении на порту вижу active rutoken устройство но в логе ошибки
[ rdpclient 554] [ 33.762530] [SCARD] Reset client.
[ rdpclient 554] [ 33.918088] Run 2 tile threads.
[ rdpclient 554] [ 34.011629] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000008.
[ rdpclient 554] [ 34.668387] [SCARD] Unknown IoControlCode 0x000900f4.
[ rdpclient 554] [ 34.675721] [SCARD] Unknown IoControlCode 0x000900fc.
[ rdpclient 554] [ 34.860221] [SCARD] Unknown IoControlCode 0x000900f4.
[ rdpclient 554] [ 34.868565] [SCARD] Unknown IoControlCode 0x000900fc.
[ rdpclient 554] [ 36.409352] [SCARD] Unknown IoControlCode 0x000900f4.
[ rdpclient 554] [ 36.418342] [SCARD] Unknown IoControlCode 0x000900fc.
[ rdpclient 554] [ 36.641296] [SCARD] Unknown IoControlCode 0x000900f4.
[ rdpclient 554] [ 36.649518] [SCARD] Unknown IoControlCode 0x000900fc.
[ rdpclient 554] [ 36.819302] SessionId 0x00000008: VILANA\ikazmina.
[ rdpclient 554] [ 36.918712] [SCARD] Unknown IoControlCode 0x000900f4.
[ rdpclient 554] [ 36.927549] [SCARD] Unknown IoControlCode 0x000900fc.
[ gm] [ 41.901848] [WTRC] Connection from 10.26.0.240.
[ gm] [ 41.935596] [WTRC] Control without password.
[ gm] [ 41.937066] [WTRC] Zoom 75%, 2 bytes per pixel.
[ SYSLOG] [ 132.533921] 1 pcscd: ccid_usb.c:892:WriteUSB() write failed (2/5): LIBUSB_ERROR_PIPE
[ SYSLOG] [ 132.533972] 1 pcscd: ifdwrapper.c:548:IFDTransmit() Card not transacted: 612
[ SYSLOG] [ 132.534001] 1 pcscd: winscard.c:1622:SCardTransmit() Card not transacted: rv=SCARD_E_NOT_TRANSACTED
[ rdpclient 554] [ 132.534077] [SCARD] SCardTransmit failed with code 0x80100016.
[ SYSLOG] [ 132.535705] 1 pcscd: ccid_usb.c:892:WriteUSB() write failed (2/5): LIBUSB_ERROR_PIPE
[ SYSLOG] [ 132.535752] 1 pcscd: ifdwrapper.c:548:IFDTransmit() Card not transacted: 612
[ SYSLOG] [ 132.535781] 1 pcscd: winscard.c:1622:SCardTransmit() Card not transacted: rv=SCARD_E_NOT_TRANSACTED
[ rdpclient 554] [ 132.535854] [SCARD] SCardTransmit failed with code 0x80100016.
[ SYSLOG] [ 132.537338] 1 pcscd: ccid_usb.c:892:WriteUSB() write failed (2/5): LIBUSB_ERROR_PIPE
[ SYSLOG] [ 132.537381] 1 pcscd: ifdwrapper.c:548:IFDTransmit() Card not transacted: 612
[ SYSLOG] [ 132.537409] 1 pcscd: winscard.c:1622:SCardTransmit() Card not transacted: rv=SCARD_E_NOT_TRANSACTED
[ rdpclient 554] [ 132.537480] [SCARD] SCardTransmit failed with code 0x80100016.
[ SYSLOG] [ 132.539084] 1 pcscd: ccid_usb.c:892:WriteUSB() write failed (2/5): LIBUSB_ERROR_PIPE
[ SYSLOG] [ 132.539125] 1 pcscd: ifdwrapper.c:548:IFDTransmit() Card not transacted: 612
[ SYSLOG] [ 132.539154] 1 pcscd: winscard.c:1622:SCardTransmit() Card not transacted: rv=SCARD_E_NOT_TRANSACTED
[ rdpclient 554] [ 132.539231] [SCARD] SCardTransmit failed with code 0x80100016.
[ SYSLOG] [ 132.540701] 1 pcscd: ccid_usb.c:892:WriteUSB() write failed (2/5): LIBUSB_ERROR_PIPE
[ SYSLOG] [ 132.540737] 1 pcscd: ifdwrapper.c:548:IFDTransmit() Card not transacted: 612
[ SYSLOG] [ 132.540766] 1 pcscd: winscard.c:1622:SCardTransmit() Card not transacted: rv=SCARD_E_NOT_TRANSACTED
[ rdpclient 554] [ 132.540845] [SCARD] SCardTransmit failed with code 0x80100016.
[ SYSLOG] [ 132.542314] 1 pcscd: ccid_usb.c:892:WriteUSB() write failed (2/5): LIBUSB_ERROR_PIPE
[ SYSLOG] [ 132.542347] 1 pcscd: ifdwrapper.c:548:IFDTransmit() Card not transacted: 612
[ SYSLOG] [ 132.542375] 1 pcscd: winscard.c:1622:SCardTransmit() Card not transacted: rv=SCARD_E_NOT_TRANSACTED
[ rdpclient 554] [ 132.542445] [SCARD] SCardTransmit failed with code 0x80100016.
[ SYSLOG] [ 132.562338] 2 pcscd: ccid_usb.c:892:WriteUSB() write failed (2/5): LIBUSB_ERROR_PIPE
[ SYSLOG] [ 132.562395] 2 pcscd: ifdwrapper.c:369:IFDStatusICC() Card not transacted: 612
[ SYSLOG] [ 132.562424] 2 pcscd: eventhandler.c:334:EHStatusHandlerThread() Error communicating to: Aktiv Rutoken ECP 00 00
[ KERNEL] [ 132.599365] usb 2-6.1.2: USB disconnect, device number 5
[ SYSLOG] [ 132.962509] 2 pcscd: ccid_usb.c:892:WriteUSB() write failed (2/5): LIBUSB_ERROR_NO_DEVICE
[ SYSLOG] [ 132.962561] 2 pcscd: ccid_usb.c:892:WriteUSB() write failed (2/5): LIBUSB_ERROR_NO_DEVICE
[ SYSLOG] [ 133.362654] 2 pcscd: ccid_usb.c:892:WriteUSB() write failed (2/5): LIBUSB_ERROR_NO_DEVICE
[ SYSLOG] [ 133.762933] 3 pcscd: ccid_usb.c:892:WriteUSB() write failed (2/5): LIBUSB_ERROR_NO_DEVICE
[ KERNEL] [ 177.365576] usb 2-6.1.1: new full-speed USB device number 6 using ehci-pci
[ KERNEL] [ 177.475884] usb 2-6.1.1: New USB device found, idVendor=0a89, idProduct=0030, bcdDevice= 1.00
[ KERNEL] [ 177.475893] usb 2-6.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 177.475898] usb 2-6.1.1: Product: Rutoken ECP
[ KERNEL] [ 177.475902] usb 2-6.1.1: Manufacturer: Aktiv
[ rdpclient 554] [ 178.146619] [SCARD] Unknown IoControlCode 0x000900f4.
[ rdpclient 554] [ 178.154685] [SCARD] Unknown IoControlCode 0x000900fc.
[ rdpclient 554] [ 178.402729] [SCARD] Unknown IoControlCode 0x000900f4.
[ rdpclient 554] [ 178.410463] [SCARD] Unknown IoControlCode 0x000900fc.
[ rdpclient 554] [ 178.652443] [SCARD] Unknown IoControlCode 0x000900f4.
[ rdpclient 554] [ 178.660652] [SCARD] Unknown IoControlCode 0x000900fc.
Re: Rutoken ЭЦП 3.0
Должно работать. В процитированном куске лога ошибки потому что токен выдернули из USB во время работы с ним.
1. Свежая версия втвари.
2. Свежие драйвера рутокена на сервере. Если ставил непомню кто и непомню когда - скачать свежие и переставить поверх.
Если это не поможет, покажи полный лог, снятый по инструкции: https://wtware.ru/logs.html
Re: Rutoken ЭЦП 3.0
понял\принял, обновлю дрова, проверю и дам обратную связь, благодарю)
