Сильно тормозит один из терминалов.
AndreyEver
Сообщение AndreyEver »
Wtware 6.2.20
Работать как локально, так и по wtrc невозможно. Лога забит вот такими ошибками. Есть идеи как поправить?
P.S. мышь подключена надежно. Пробовали переподключать в другой USB порт
[            gm] [181325.575077]                           evdev-device.cpp (  857): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[        KERNEL] [181325.558940] usb 1-1.3: USB disconnect, device number 60
[            gm] [181325.575138] [EVDEV] Close input device 'PixArt USB Optical Mouse', errno 19.
[        KERNEL] [181325.804184] usb 1-1.3: new low-speed USB device number 61 using ehci-pci
[        KERNEL] [181325.916437] usb 1-1.3: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
[        KERNEL] [181325.916445] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [181325.916448] usb 1-1.3: Product: USB Optical Mouse
[        KERNEL] [181325.916451] usb 1-1.3: Manufacturer: PixArt
[        KERNEL] [181325.919204] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:093A:2510.003A/input/input64
[        KERNEL] [181325.919343] hid-generic 0003:093A:2510.003A: input,hidraw1: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:1a.0-1.3/input0
[ rdpclient 491] [181397.857875] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [181467.310601] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [182265.350051] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [182321.521101] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [182901.246844] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [183836.709493] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [183839.400680] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [183867.833789] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [183897.230052] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [183912.680321] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [183916.359877] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [183929.953696] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [183931.781159] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [184259.079029] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [184263.740507] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [184264.660374] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [184293.535915] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [184326.605713] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [184416.137076] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [184419.238468] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [184429.195788] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [184479.949825] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [184480.160941] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [184534.536068] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [184716.245307] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [184716.435637] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [184774.276107] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [184775.479631] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [184777.245846] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [184957.233352] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [184957.316225] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [184994.666119] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [185002.343206] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [185002.353426] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [185791.811416] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [185892.549152] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [188486.532784] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [188581.241809] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [188581.515672] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [208242.936465] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [208243.065062] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[        KERNEL] [336914.110912] usb 1-1.3: USB disconnect, device number 61
[            gm] [336914.144201]                           evdev-device.cpp (  857): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[            gm] [336914.144245] [EVDEV] Close input device 'PixArt USB Optical Mouse', errno 19.
[        KERNEL] [336914.353156] usb 1-1.3: new low-speed USB device number 62 using ehci-pci
[        KERNEL] [336914.469405] usb 1-1.3: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
[        KERNEL] [336914.469413] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [336914.469417] usb 1-1.3: Product: USB Optical Mouse
[        KERNEL] [336914.469419] usb 1-1.3: Manufacturer: PixArt
[        KERNEL] [336914.472175] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:093A:2510.003B/input/input65
[        KERNEL] [336914.472322] hid-generic 0003:093A:2510.003B: input,hidraw1: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:1a.0-1.3/input0
[ rdpclient 491] [336923.377674] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [338519.932584] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [338524.637353] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [340683.135395] [ClearCodec debug] The cursor has gone over the edge.
Re: Сильно тормозит один из терминалов.
Не вижу ничего плохого для обрывка лога за четверо суток работы. В первые сутки проблема есть? Покажи лог целиком.
AndreyEver
Станцию ребутнули. Пришлю как только опять начнет чудить. Но в логе постоянные
после которых стабильно идет
и сново переподлючаем мышь.
AndreyEver писал(а): Ср апр 24, 2024 11:57 am [ rdpclient 491] [208243.065062]...
Между этими событиями 35 часов!
AndreyEver
Сильно помогло уменьшение TCP MSS в кпд.
Кто такой кпд?
alfes
Сообщение alfes »
У меня такой же в логах срач и тормоза. Железо малинка 4. Уважаемы АКА, прокомментируйте пожалуйста, если нужна инфа скажите что снять - сниму.
[ rdpclient 756] [  485.030806] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  486.034270] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  488.237618] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  489.248477] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  489.763677] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [  499.779664] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  502.168122] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  530.566940] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  531.934557] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [  532.056598] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  547.123747] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  551.960146] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  553.348220] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  554.018673] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [  554.495895] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  559.802427] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  561.298508] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  563.360093] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  563.403673] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [  569.956285] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  605.554042] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  614.878956] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  615.908709] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [  618.655454] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  620.828947] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  628.930938] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  657.934585] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [  660.218505] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  719.348222] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  737.165910] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  738.373887] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  738.687969] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [  739.602650] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  741.987470] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  744.027693] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  750.124554] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [  751.455938] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  816.472986] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  820.837318] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  822.482925] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  822.483339] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [  825.674003] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  829.042698] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  831.179346] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  837.692379] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [  838.244209] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  839.246057] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  845.012957] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  845.892163] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  848.042374] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [  848.884547] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  851.240517] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  853.804230] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  886.472270] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [  890.375473] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  933.738761] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  948.076195] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [  949.404894] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [  958.232540] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [  971.743643] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1065.752807] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1090.404996] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [ 1167.599830] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1266.610739] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1273.408565] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1316.257103] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [ 1425.090685] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1425.289910] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1431.839470] [SOUND] AAC compressed sound 44100 frames per second.
[ rdpclient 756] [ 1431.839643] [ALSA] Start speaker plugin.
[ rdpclient 756] [ 1432.057197] [ALSA PLAY] Use device hw:1,0.
[ rdpclient 756] [ 1432.062290] [ALSA PLAY] Hardware rate 44100Hz stereo.
[ rdpclient 756] [ 1432.062688] [ALSA PLAY] Chunk size 1024 frames, 4096 bytes, 23 msec.
[ rdpclient 756] [ 1435.141500] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [ 1437.070131] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1442.703878] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1443.638206] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1445.712497] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1445.743049] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [ 1460.034628] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1463.270457] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1515.740076] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [ 1534.887292] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1535.310213] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1544.327898] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1545.258753] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1546.462970] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [ 1548.040738] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1548.432823] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1551.139247] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1551.146077] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1551.331978] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [ 1560.863929] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1560.959793] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1569.536737] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [ 1574.183302] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1574.191813] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1583.815993] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1583.816203] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1586.994701] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [ 1593.027983] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1593.429819] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1624.856724] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [ 1626.821681] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1626.823885] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1656.131281] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1656.706590] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1681.938863] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [ 1700.825170] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1700.828325] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1738.423720] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1738.431879] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [ 1738.432200] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1748.184851] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 756] [ 1748.281376] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 756] [ 1754.302482] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 756] [ 1861.289326] [ClearCodec debug] Short cursor has gone over the edge.
Не вижу проблемы в этом обрывке лога. Этот мусор - попытки ловить то черную полосу, то белую, которая иногда на двух мониторах вместо графики лезет, пока безуспешные. Единственное, что я могу сказать по этому логу - что терминал активно что-то рисует, на экране совсем не Word.
Прочитать методичку про логи, снять лог выполнив первые четыре пнукта так, как написано: http://wtware.ru/logs.html Показать лог целиком, от загрузки до первого проявления проблемы.
