16-40-43-853| [ rdpsnd] [ 1259.143430] Link lost.
16-40-45-710| [ gm] [ 1261.025480] Run '/sbin/resolver 0x1d40718 dns [vm-term-cb01.technodom.kz]', log '', env '', pid ''.
16-40-45-928| [ pfac] [ 1261.025649] Run /sbin/resolver 0x1d40718 dns [vm-term-cb01.technodom.kz].
16-40-45-928| [ pfac] [ 1261.025665] Ok, PID 977.
16-40-45-944| [ pfac] [ 1261.027825] Process pid 977 terminated, status 00000000.
16-40-45-959| [ gm] [ 1261.030034] vm-term-cb01.technodom.kz => 172.16.12.152.
16-40-55-944| [ gm] [ 1271.264231] Free ram before fork terminal client /sbin/rdpclient-SSE (session 5): 1892636 Kb.
16-40-55-959| [ gm] [ 1271.264292] Run '/sbin/rdpclient-SSE 5', log '/tmp/rdpclient.out', env '', pid ''.
16-40-55-959| [ pfac] [ 1271.264401] Run /sbin/rdpclient-SSE 5.
16-40-55-959| [ pfac] [ 1271.264414] Ok, PID 978.
16-40-55-991| [ rdpclient 978] [ 1271.270179] Username: "tsexpress".
16-40-56-006| [ rdpclient 978] [ 1271.270191] Password: present.
16-40-56-006| [ rdpclient 978] [ 1271.270203] No PIN.
16-40-56-022| [ rdpclient 978] [ 1271.270214] Domain: "technodom".
16-40-56-022| [ rdpclient 978] [ 1271.270238] No shell.
16-40-56-037| [ rdpclient 978] [ 1271.270249] No directory.
16-40-56-037| [ rdpclient 978] [ 1271.270260] Window: 1600x900@24.
16-40-56-037| [ rdpclient 978] [ 1271.270270] Second monitor: [1600:0..3199:899].
16-40-56-037| [ rdpclient 978] [ 1271.270280] PFlags 0x00000184.
16-40-56-053| [ rdpclient 978] [ 1271.270291] Keyboard 00000409:00000000.
16-40-56-053| [ rdpclient 978] [ 1271.270301] My hostname "wtw001999D40420".
16-40-56-147| [ rdpclient 978] [ 1271.368735] Server 172.16.12.151.
16-40-56-162| [ rdpclient 978] [ 1271.368750] User "tsexpress".
16-40-56-162| [ rdpclient 978] [ 1271.368762] Domain "TECHNODOM".
16-40-56-162| [ gm] [ 1271.368772] TSClient (sessionId 5, pid 978) gracefully end.
16-40-56-178| [ pfac] [ 1271.369067] Run /sbin/rdpclient-SSE 6.
16-40-56-178| [ gm] [ 1271.369077] Free ram before fork terminal client /sbin/rdpclient-SSE (session 6): 1892140 Kb.
16-40-56-193| [ pfac] [ 1271.369091] Ok, PID 979.
16-40-56-193| [ gm] [ 1271.369095] Run '/sbin/rdpclient-SSE 6', log '/tmp/rdpclient.out', env '', pid ''.
16-40-56-209| [ rdpsnd] [ 1271.369236] Link lost.
16-40-56-209| [ pfac] [ 1271.369295] Process pid 978 terminated, status 00000009.
16-40-56-240| [ rdpclient 979] [ 1271.371113] Username: "tsexpress".
16-40-56-240| [ rdpclient 979] [ 1271.371132] Password: present.
16-40-56-240| [ rdpclient 979] [ 1271.371150] No PIN.
16-40-56-240| [ rdpclient 979] [ 1271.371169] Domain: "TECHNODOM".
16-40-56-256| [ rdpclient 979] [ 1271.371187] No shell.
16-40-56-256| [ rdpclient 979] [ 1271.371206] No directory.
16-40-56-256| [ rdpclient 979] [ 1271.371225] Window: 1600x900@24.
16-40-56-271| [ rdpclient 979] [ 1271.371246] Second monitor: [1600:0..3199:899].
16-40-56-271| [ rdpclient 979] [ 1271.371265] PFlags 0x00000184.
16-40-56-271| [ rdpclient 979] [ 1271.371284] Keyboard 00000409:00000000.
16-40-56-287| [ rdpclient 979] [ 1271.371303] My hostname "wtw001999D40420".
16-41-17-051| [ gm] [ 1292.251500] TSClient (sessionId 6, pid 979) gracefully end.
16-41-17-067| [ rdpsnd] [ 1292.255364] Link lost.
А вот с отключенным NLA
16-50-50-312| [ rdpsnd] [ 138.522063] Link lost.
16-50-50-312| [ pfac] [ 138.522180] Process pid 950 terminated, status 00000009.
16-50-51-202| [ gm] [ 139.427367] Run '/sbin/resolver 0x1b236d0 dns [vm-term-cb01.technodom.kz]', log '', env '', pid ''.
16-50-51-233| [ pfac] [ 139.427556] Run /sbin/resolver 0x1b236d0 dns [vm-term-cb01.technodom.kz].
16-50-51-233| [ pfac] [ 139.427656] Ok, PID 961.
16-50-51-248| [ pfac] [ 139.429872] Process pid 961 terminated, status 00000000.
16-50-51-248| [ gm] [ 139.431674] vm-term-cb01.technodom.kz => 172.16.12.152.
16-50-51-248| [ gm] [ 139.456231] Free ram before fork terminal client /sbin/rdpclient-SSE (session 2): 1892728 Kb.
16-50-51-248| [ gm] [ 139.456277] Run '/sbin/rdpclient-SSE 2', log '/tmp/rdpclient.out', env '', pid ''.
16-50-51-264| [ pfac] [ 139.456399] Run /sbin/rdpclient-SSE 2.
16-50-51-264| [ pfac] [ 139.456421] Ok, PID 962.
16-50-51-280| [ rdpclient 962] [ 139.457729] RDP Terminal Client, WTware 5.8.34, pipe 2, pid 962.
16-50-51-280| [ rdpclient 962] [ 139.460406] Use /lib/ui32-SSE.so.
16-50-51-280| [ rdpclient 962] [ 139.460841] Redirect sound.
16-50-51-280| [ rdpclient 962] [ 139.461074] Make RDP session with 172.16.12.152, port 3389.
16-50-51-295| [ rdpclient 962] [ 139.461103] No username.
16-50-51-295| [ rdpclient 962] [ 139.461123] No password.
16-50-51-295| [ rdpclient 962] [ 139.461143] No PIN.
16-50-51-295| [ rdpclient 962] [ 139.461166] Domain: "technodom".
16-50-51-311| [ rdpclient 962] [ 139.461186] No shell.
16-50-51-311| [ rdpclient 962] [ 139.461206] No directory.
16-50-51-326| [ rdpclient 962] [ 139.461226] Window: 1600x900@24.
16-50-51-326| [ rdpclient 962] [ 139.461248] Second monitor: [1600:0..3199:899].
16-50-51-326| [ rdpclient 962] [ 139.461270] PFlags 0x00000184.
16-50-51-326| [ rdpclient 962] [ 139.461292] Keyboard 00000409:00000000.
16-50-51-342| [ rdpclient 962] [ 139.461361] My hostname "wtw001999D40420".
16-50-51-342| [ rdpclient 962] [ 139.461387] TCP: connecting to 172.16.12.152:3389.
16-50-51-451| [ rdpclient 962] [ 139.461880] TCP: connection with 172.16.12.152:3389 established.
16-50-51-451| [ rdpclient 962] [ 139.461918] Turn keepalive on.
16-50-51-451| [ rdpclient 962] [ 139.462122] Free ram after buffers allocation: 1892224 KB.
16-50-51-451| [ rdpclient 962] [ 139.462148] Use Balance Info 52 bytes: 'tsv://MS Terminal Services Plugin.1.vm-terminal-2016'.
16-50-51-467| [ rdpclient 962] [ 139.465132] Reconnect with TLS/SSL enabled.
16-50-51-467| [ rdpclient 962] [ 139.465183] TCP: reconnecting to 172.16.12.152:3389.
16-50-51-482| [ rdpclient 962] [ 139.465537] TCP: connection with 172.16.12.152:3389 established.
16-50-51-482| [ rdpclient 962] [ 139.465569] Turn keepalive on.
16-50-51-482| [ rdpclient 962] [ 139.465601] Use Balance Info 52 bytes: 'tsv://MS Terminal Services Plugin.1.vm-terminal-2016'.
16-50-51-498| [ rdpclient 962] [ 139.467681] Server supports GFX Pipeline.
16-50-51-498| [ rdpclient 962] [ 139.467715] TLS.
16-50-51-498| [ rdpclient 962] [ 139.467738] SSL/TLS.
16-50-51-514| [ rdpclient 962] [ 139.476915] Enable font smoothing and Desktop Composition.
16-50-51-514| [ rdpclient 962] [ 139.508754] GFX codec.
16-50-51-654| [ rdpclient 962] [ 139.843600] Run 2 tile threads.
16-51-28-892| [ gm] [ 177.116961] Power key pressed.
- IMG_20190329_172400.jpg (206.35 КБ) 93201 просмотр
