Переход с версии 4.6.11 на 5.0.1 (ошибка загрузки)
jonn_t
Сообщение jonn_t »
В 4.6.11 проблем небыло ,решили попробовать 5.0.1.
В настройках MS DHCP Reservation Options меняем 067 BootFile Name
с PRO\4.6.11\wtware.pxe на 5.0.1\wtware.pxe ,в результате
перестаёт загружаться пишет нет сервера DHCP.
[192.168.50.224] Got RRQ, 31 bytes.
[192.168.50.224] 00000000: 35 2e 30 2e 31 5c 77 74 77 61 72 65 2e 70 78 65
[192.168.50.224] 00000010: 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00
[192.168.50.224] Requests file "5.0.1\wtware.pxe". Tsize is requested, blksize default.
[192.168.50.224] Sending OASK (tsize 16282).
[192.168.50.224] Received opcode 5.
[192.168.50.224] 00000000: 00 05 00 00 54 46 54 50 20 41 62 6f 72 74 65 64
[192.168.50.224] Got RRQ, 36 bytes.
[192.168.50.224] 00000010: 00 6f 63 74 65 74 00 62 6c 6b 73 69 7a 65 00 31
[192.168.50.224] 00000020: 34 35 36 00
[192.168.50.224] Request block size 1456, forced to 1240.
[192.168.50.224] Requests file "5.0.1\wtware.pxe". Tsize is not requested, blksize 1240 bytes.
[192.168.50.224] Sending OASK (blksize 1240).
[192.168.50.224] Transfer of file "5.0.1\wtware.pxe" completed.
[192.168.50.224] Connection closed.
[192.168.50.224] Got RRQ, 70 bytes.
[192.168.50.224] 00000000: 35 2e 30 2e 31 5c 30 30 30 30 30 30 30 30 2d 30
[192.168.50.224] 00000010: 30 30 30 2d 30 30 30 30 2d 30 30 30 30 2d 30 30
[192.168.50.224] 00000020: 30 30 30 30 30 30 30 30 30 30 00 6f 63 74 65 74
[192.168.50.224] 00000030: 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65
[192.168.50.224] 00000040: 00 31 34 30 38 00
[192.168.50.224] Request block size 1408, forced to 1240.
[192.168.50.224] Requests file "5.0.1\00000000-0000-0000-0000-000000000000". Tsize is requested, blksize 1240 bytes.
[192.168.50.224] Requested file "C:\Program Files\WTware\TFTPDROOT\5.0.1\00000000-0000-0000-0000-000000000000" not found.
[192.168.50.224] Got RRQ, 54 bytes.
[192.168.50.224] 00000000: 35 2e 30 2e 31 5c 30 31 2d 30 30 2d 65 30 2d 31
[192.168.50.224] 00000010: 38 2d 33 66 2d 32 64 2d 35 66 00 6f 63 74 65 74
[192.168.50.224] 00000020: 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65
[192.168.50.224] 00000030: 00 31 34 30 38 00
[192.168.50.224] Requests file "5.0.1\01-00-e0-18-3f-2d-5f". Tsize is requested, blksize 1240 bytes.
[192.168.50.224] Requested file "C:\Program Files\WTware\TFTPDROOT\5.0.1\01-00-e0-18-3f-2d-5f" not found.
[192.168.50.224] Got RRQ, 42 bytes.
[192.168.50.224] 00000000: 35 2e 30 2e 31 5c 43 30 41 38 33 32 45 30 00 6f
[192.168.50.224] 00000010: 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b
[192.168.50.224] 00000020: 73 69 7a 65 00 31 34 30 38 00
[192.168.50.224] Requests file "5.0.1\C0A832E0". Tsize is requested, blksize 1240 bytes.
[192.168.50.224] Requested file "C:\Program Files\WTware\TFTPDROOT\5.0.1\C0A832E0" not found.
[192.168.50.224] Got RRQ, 41 bytes.
[192.168.50.224] 00000000: 35 2e 30 2e 31 5c 43 30 41 38 33 32 45 00 6f 63
[192.168.50.224] 00000010: 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73
[192.168.50.224] 00000020: 69 7a 65 00 31 34 30 38 00
[192.168.50.224] Requests file "5.0.1\C0A832E". Tsize is requested, blksize 1240 bytes.
[192.168.50.224] Requested file "C:\Program Files\WTware\TFTPDROOT\5.0.1\C0A832E" not found.
[192.168.50.224] Got RRQ, 40 bytes.
[192.168.50.224] 00000000: 35 2e 30 2e 31 5c 43 30 41 38 33 32 00 6f 63 74
[192.168.50.224] 00000010: 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69
[192.168.50.224] 00000020: 7a 65 00 31 34 30 38 00
[192.168.50.224] Requests file "5.0.1\C0A832". Tsize is requested, blksize 1240 bytes.
[192.168.50.224] Requested file "C:\Program Files\WTware\TFTPDROOT\5.0.1\C0A832" not found.
[192.168.50.224] Got RRQ, 39 bytes.
[192.168.50.224] 00000000: 35 2e 30 2e 31 5c 43 30 41 38 33 00 6f 63 74 65
[192.168.50.224] 00000010: 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a
[192.168.50.224] 00000020: 65 00 31 34 30 38 00
[192.168.50.224] Requests file "5.0.1\C0A83". Tsize is requested, blksize 1240 bytes.
[192.168.50.224] Requested file "C:\Program Files\WTware\TFTPDROOT\5.0.1\C0A83" not found.
[192.168.50.224] Got RRQ, 38 bytes.
[192.168.50.224] 00000000: 35 2e 30 2e 31 5c 43 30 41 38 00 6f 63 74 65 74
[192.168.50.224] 00000010: 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65
[192.168.50.224] 00000020: 00 31 34 30 38 00
[192.168.50.224] Requests file "5.0.1\C0A8". Tsize is requested, blksize 1240 bytes.
[192.168.50.224] Requested file "C:\Program Files\WTware\TFTPDROOT\5.0.1\C0A8" not found.
[192.168.50.224] Got RRQ, 37 bytes.
[192.168.50.224] 00000000: 35 2e 30 2e 31 5c 43 30 41 00 6f 63 74 65 74 00
[192.168.50.224] 00000010: 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00
[192.168.50.224] 00000020: 31 34 30 38 00
[192.168.50.224] Requests file "5.0.1\C0A". Tsize is requested, blksize 1240 bytes.
[192.168.50.224] Requested file "C:\Program Files\WTware\TFTPDROOT\5.0.1\C0A" not found.
[192.168.50.224] 00000000: 35 2e 30 2e 31 5c 43 30 00 6f 63 74 65 74 00 74
[192.168.50.224] 00000010: 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31
[192.168.50.224] 00000020: 34 30 38 00
[192.168.50.224] Requests file "5.0.1\C0". Tsize is requested, blksize 1240 bytes.
[192.168.50.224] Requested file "C:\Program Files\WTware\TFTPDROOT\5.0.1\C0" not found.
[192.168.50.224] Got RRQ, 35 bytes.
[192.168.50.224] 00000000: 35 2e 30 2e 31 5c 43 00 6f 63 74 65 74 00 74 73
[192.168.50.224] 00000010: 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34
[192.168.50.224] 00000020: 30 38 00
[192.168.50.224] Requests file "5.0.1\C". Tsize is requested, blksize 1240 bytes.
[192.168.50.224] Requested file "C:\Program Files\WTware\TFTPDROOT\5.0.1\C" not found.
[192.168.50.224] 00000000: 35 2e 30 2e 31 5c 70 78 65 2e 63 66 67 00 6f 63
[192.168.50.224] Requests file "5.0.1\pxe.cfg". Tsize is requested, blksize 1240 bytes.
[192.168.50.224] Sending OASK (tsize 233, blksize 1240).
[192.168.50.224] Transfer of file "5.0.1\pxe.cfg" completed.
[192.168.50.224] Got RRQ, 49 bytes.
[192.168.50.224] 00000000: 35 2e 30 2e 31 5c 70 61 63 6b 61 67 65 73 2f 6b
[192.168.50.224] 00000010: 65 72 6e 65 6c 00 6f 63 74 65 74 00 74 73 69 7a
[192.168.50.224] 00000020: 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 38
[192.168.50.224] Requests file "5.0.1\packages\kernel". Tsize is requested, blksize 1240 bytes.
[192.168.50.224] Sending OASK (tsize 1673552, blksize 1240).
[192.168.50.224] Incorrect ACK received (expected 926, received 925).
[192.168.50.224] Incorrect ACK received (expected 927, received 926).
[192.168.50.224] Incorrect ACK received (expected 928, received 927).
[192.168.50.224] Incorrect ACK received (expected 929, received 928).
[192.168.50.224] Transfer of file "5.0.1\packages\kernel" completed.
[192.168.50.224] 00000000: 35 2e 30 2e 31 5c 70 61 63 6b 61 67 65 73 2f 69
[192.168.50.224] 00000010: 6e 69 74 72 64 00 6f 63 74 65 74 00 74 73 69 7a
[192.168.50.224] Requests file "5.0.1\packages\initrd". Tsize is requested, blksize 1240 bytes.
[192.168.50.224] Sending OASK (tsize 4017668, blksize 1240).
[192.168.50.224] Incorrect ACK received (expected 765, received 764).
[192.168.50.224] Incorrect ACK received (expected 767, received 766).
[192.168.50.224] Incorrect ACK received (expected 768, received 767).
[192.168.50.224] Incorrect ACK received (expected 769, received 768).
[192.168.50.224] Incorrect ACK received (expected 845, received 844).
[192.168.50.224] Incorrect ACK received (expected 846, received 845).
[192.168.50.224] Incorrect ACK received (expected 847, received 846).
[192.168.50.224] Incorrect ACK received (expected 849, received 848).
[192.168.50.224] Incorrect ACK received (expected 850, received 849).
[192.168.50.224] Incorrect ACK received (expected 852, received 851).
[192.168.50.224] Incorrect ACK received (expected 1091, received 1090).
[192.168.50.224] Incorrect ACK received (expected 1092, received 1091).
[192.168.50.224] Incorrect ACK received (expected 2537, received 2536).
[192.168.50.224] Incorrect ACK received (expected 2538, received 2537).
[192.168.50.224] Incorrect ACK received (expected 2901, received 2900).
[192.168.50.224] Incorrect ACK received (expected 2904, received 2903).
[192.168.50.224] Incorrect ACK received (expected 2905, received 2904).
[192.168.50.224] Incorrect ACK received (expected 2907, received 2906).
[192.168.50.224] Incorrect ACK received (expected 3064, received 3063).
[192.168.50.224] Incorrect ACK received (expected 3065, received 3064).
[192.168.50.224] Incorrect ACK received (expected 3066, received 3065).
[192.168.50.224] Incorrect ACK received (expected 3067, received 3066).
[192.168.50.224] Incorrect ACK received (expected 3068, received 3067).
[192.168.50.224] Incorrect ACK received (expected 3069, received 3068).
[192.168.50.224] Transfer of file "5.0.1\packages\initrd" completed.
[192.168.50.224] Timeout occured while transfer "5.0.1\wtware.pxe".
[192.168.50.224] Client not responding. Connection closed.
Что может быть.
Пробовали загрузку с HDD (другой компьютер) всё нормально.
Re: Переход с версии 4.6.11 на 5.0.1 (ошибка загрузки)
Сеть чинить надо. Сеть в этом случае начинается от драйвера сетевой карты сервера и заканчивается биосом терминала.
[quote="aka"]Сеть чинить надо. Сеть в этом случае начинается от драйвера сетевой карты сервера и заканчивается биосом терминала.[/quote]
1. Так ведь 4.6.11 грузиться без проблем по .pxe;
2. Более того, 5.0.1 грузиться по .nbi
Что, загрузка 5.0.1 по pxe более чувствительна к качеству сети??? Или дело в чем то другом?
jonn_t
Сообщение jonn_t »
Сохранили два лога:
1.WTware4611_TFTP_2011-08-22_09-36-10.txt - с этой же машины версия 4.6.11 загрузка по PXE. Загружается!
2.WTware501nbi_TFTP_2011-08-22_09-54-02.txt - с другой машины версия 5.0.1 загрузка по NBI. Загружается!
Может что подскажите более конкретно.
(11.14 КБ) 1567 скачиваний
(32.69 КБ) 1458 скачиваний
Я вопрос не понимаю.
Протокол TFTP, по которому происходит передача файлов при загрузке по сети, ОЧЕНЬ чувствителен к кривизне сети. Там, где умный TCP со всеми его окнами и ретрейнами немного сбросит скорость, там TFTP заткнется. Поэтому сеть, по которой загружаются, должна быть не просто "винда же работает", а действительно исправна. Сеть в этом случае начинается от драйвера сетевой карты сервера, затем провода, розетки, настройки свича, и заканчивается биосом терминала. Методом перебора надо найти неисправное звено и заменить.
jonn_t
Сообщение jonn_t »
aka писал(а):Я вопрос не понимаю.
Так что не понятного.
Предыдущая версия использовала другой протокол что ли?
И почему тогда по NBI грузится то же используется другой протокол?
Явно произошли изменения в программе если одна работает ,а другая нет.
Какая то проверка которая у нас не проходит.
Поделитесь. Будем рады.
jonn_t
Сообщение jonn_t »
После продолжительных боёв.
Выяснили что дело в свичах. У нас AT-8000S/48 (таких свичей два и проблема на обоих).
С другими свичами всё работает.
С наскоку исправить не получилось.
Может подскажете какие могут настройки повлиять на работу.
Однако староя версия работает и на AT-8000S/48 :roll:
jonn_t писал(а):Какая то проверка которая у нас не проходит.
Вот это:
Означает "сеть неисправна, почините". Я не понимаю, зачем пытаться на неисправной сети загружать машину дальше и искать, обо что она споткнется. Конфликт свича и сетевой карты вполне может быть причиной.
