Поддерживается ли донгл на чипе RTL8192CU?
Добавлено: Вт окт 24, 2017 8:07 am
Собственно сабж, есть tp-link tl-wn823n, хотелось бы узнать поддержки драйвера в vtware.
Клиент удаленного рабочего стола и операционная система тонких клиентов для загрузки по сети
https://forum.wtware.ru/forum/
[ initrd] [ 7.380727] Unpack /bootmedia/packages/pi2-xnet.
[ initrd] [ 8.147144] modprobe rtl8192cu.
[ KERNEL] [ 8.162560] rtl8192cu: Chip version 0x11
[ KERNEL] [ 8.210881] rtl8192cu: Board Type 0
[ KERNEL] [ 8.210987] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ KERNEL] [ 8.211062] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[ KERNEL] [ 8.211135] usb 1-1.4.1.4: Direct firmware load for rtlwifi/rtl8192cufw_TMSC.bin failed with error -2
[ KERNEL] [ 8.211140] usb 1-1.4.1.4: Falling back to user helper
[ hotplug] [ 8.207502] hotplug-main.cpp ( 297): -- ERROR -- Firmware "/lib/firmware/rtlwifi/rtl8192cufw_TMSC.bin" not found.
[ KERNEL] [ 8.213212] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ KERNEL] [ 8.214441] usbcore: registered new interface driver rtl8192cu
[ KERNEL] [ 8.216312] rtl8192cu 1-1.4.1.4:1.0 eth0: renamed from wlan0
[ initrd] [ 8.260374] Failed to disable WiFi Power Management.
[ KERNEL] [ 69.605857] usb 1-1.4.1.4: Direct firmware load for rtlwifi/rtl8192cufw.bin failed with error -2
[ KERNEL] [ 69.605868] usb 1-1.4.1.4: Falling back to user helper
[ hotplug] [ 69.602773] hotplug-main.cpp ( 297): -- ERROR -- Firmware "/lib/firmware/rtlwifi/rtl8192cufw.bin" not found.
[ KERNEL] [ 131.045771] rtlwifi: Loading alternative firmware rtlwifi/rtl8192cufw.bin
[ KERNEL] [ 131.045779] rtlwifi: Selected firmware is not available
09-06-54-776| [ initrd] [ 7.229142] +------------------------
09-06-54-776| [ initrd] [ 7.229314] Unpack /bootmedia/packages/pi2-xnet.
09-06-54-776| [ initrd] [ 8.030579] modprobe rtl8192cu.
09-06-54-776| [ KERNEL] [ 8.042600] rtl8192cu: Chip version 0x11
09-06-54-776| [ KERNEL] [ 8.091083] rtl8192cu: Board Type 0
09-06-54-776| [ KERNEL] [ 8.091184] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
09-06-54-776| [ KERNEL] [ 8.091251] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
09-06-54-776| [ KERNEL] [ 8.091781] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
09-06-54-776| [ KERNEL] [ 8.092956] usbcore: registered new interface driver rtl8192cu
09-06-54-776| [ KERNEL] [ 8.094267] rtl8192cu 1-1.4:1.0 eth0: renamed from wlan0
09-06-54-776| [ initrd] [ 8.143358] Failed to disable WiFi Power Management.
