HP ScanJet 3800c
Добавлено: Вт июл 25, 2017 3:59 pm
Sane выдает No device Connected.
Файл sane в twain_32 директорию забрасывали, терминал на win10 64.
В конфигурации
scanner=on
В конфигурации
scanner=on
WTware 5.4.98
Close connection with wtc.exe.
[ KERNEL] [ 6953.569230] usb 5-1: USB disconnect, device number 2
[ KERNEL] [ 6953.569490] usblp0: removed
[ KERNEL] [ 6971.596001] usb 5-1: new high-speed USB device number 3 using xhci_hcd
[ KERNEL] [ 6971.738894] usb 5-1: New USB device found, idVendor=03f0, idProduct=042a
[ KERNEL] [ 6971.738901] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ KERNEL] [ 6971.738905] usb 5-1: Product: HP LaserJet Professional M1132 MFP
[ KERNEL] [ 6971.738908] usb 5-1: Manufacturer: Hewlett-Packard
[ KERNEL] [ 6971.738911] usb 5-1: SerialNumber: 000000000QHA9HSFSI1c
[ KERNEL] [ 6971.740200] usb-storage 5-1:1.0: USB Mass Storage device detected
[ KERNEL] [ 6971.740407] scsi host4: usb-storage 5-1:1.0
[ KERNEL] [ 6973.512301] usb 5-1: USB disconnect, device number 3
[ KERNEL] [ 6974.004002] usb 5-1: new high-speed USB device number 4 using xhci_hcd
[ KERNEL] [ 6974.150906] usb 5-1: New USB device found, idVendor=03f0, idProduct=042a
[ KERNEL] [ 6974.150912] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ KERNEL] [ 6974.150916] usb 5-1: Product: HP LaserJet Professional M1132 MFP
[ KERNEL] [ 6974.150919] usb 5-1: Manufacturer: Hewlett-Packard
[ KERNEL] [ 6974.150922] usb 5-1: SerialNumber: 000000000QHA9HSFPR1a
[ KERNEL] [ 6974.155491] usblp 5-1:1.0: usblp0: USB Bidirectional printer dev 4 if 0 alt 0 proto 2 vid 0x03F0 pid 0x042A
[rdpclient 1081] [13785.936276] errorInfo 0x0000000c.
[rdpclient 1081] [13785.936359] ERRINFO_LOGOFF_BY_USER
[rdpclient 1081] [13786.055774] Receive Disconnect Provider Ultimatum.
[ gm] [13786.060115] TSClient (sessionId 2, pid 1081) gracefully end.
[ rdpsnd] [13786.071653] Link lost.
[RDP] close kotopipe (n = 0, errno 11).
[ pfac] [13786.072032] Process pid 1081 terminated, status 00000009.
[ KERNEL] [28299.300489] usb 5-1: USB disconnect, device number 4
[ KERNEL] [28299.300811] usblp0: removed
[ gm] [68016.138963] Run '/sbin/resolver 0x8da6260 dns [TS-RDS01.domain.LOCAL]', log '', env '', pid ''.
[ pfac] [68016.139247] Run /sbin/resolver 0x8da6260 dns [TS-RDS01.domain.LOCAL].
[ pfac] [68016.139433] Ok, PID 1135.
[ gm] [68016.148324] TS-RDS01.domain.LOCAL => 10.99.99.171.
[ pfac] [68016.148460] Process pid 1135 terminated, status 00000000.
[ gm] [68016.148665] Free ram before fork terminal client /sbin/rdpclient-SSE (session 3): 2465400 Kb.
[ pfac] [68016.148706] Run /sbin/rdpclient-SSE 3.
[ gm] [68016.148727] Run '/sbin/rdpclient-SSE 3', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [68016.148761] Ok, PID 1136.
[rdpclient 1136] [68016.151044] RDP Terminal Client, WTware 5.4.98, pipe 3, pid 1136.
[ gm] [68016.151399] ERROR: usb-serial device 1c4f:0002 not found.
[rdpclient 1136] [68016.151426] Use /lib/ui32-SSE.so.
[ gm] [68016.151462] Do NOT redirect COM1.
[ gm] [68016.151497] ERROR: usb-serial device 1395:0025 not found.
[ gm] [68016.151532] Do NOT redirect COM2.
[ gm] [68016.151567] ERROR: usb-serial device 03f0:042a not found.
[ gm] [68016.151601] Do NOT redirect COM2.
[rdpclient 1136] [68016.151667] Add RDP printer redirection for "HP LaserJet Professional M1132 MFP".
[rdpclient 1136] [68016.151707] Redirect sound.
[rdpclient 1136] [68016.151799] Make RDP session with 10.99.99.171, port 3389.
[rdpclient 1136] [68016.151838] No username.
[rdpclient 1136] [68016.151876] No password.
[rdpclient 1136] [68016.151913] No PIN.
[rdpclient 1136] [68016.151951] Domain: "domain.local".
[rdpclient 1136] [68016.151988] No shell.
[rdpclient 1136] [68016.152043] No directory.
[rdpclient 1136] [68016.152081] Window: 1216x960@24.
[rdpclient 1136] [68016.152118] PFlags 0x0000002E.
[rdpclient 1136] [68016.152154] Keyboard 00000409:00000000.
[rdpclient 1136] [68016.152192] My hostname "ts1-client1".
[rdpclient 1136] [68016.152229] TCP: connecting to 10.99.99.171:3389.
[rdpclient 1136] [68016.158848] TCP: connection with 10.99.99.171:3389 established.
[rdpclient 1136] [68016.158932] Turn keepalive on.
[rdpclient 1136] [68016.159147] Free ram after buffers allocation: 2464648 KB.
[rdpclient 1136] [68016.159187] Use Balance Info 28 bytes: 'tsv://VMResource.1.POOL'.
[rdpclient 1136] [68027.344810] Reconnect with CredSSP enabled.
[rdpclient 1136] [68027.344878] TCP: reconnecting to 10.99.99.171:3389.
[rdpclient 1136] [68027.351609] TCP: connection with 10.99.99.171:3389 established.
[rdpclient 1136] [68027.351694] Turn keepalive on.
[rdpclient 1136] [68027.351732] Use Balance Info 28 bytes: 'tsv://VMResource.1.POOL'.
[rdpclient 1136] [68027.360994] Server supports GFX Pipeline.
[rdpclient 1136] [68027.361084] CredSSP.
[rdpclient 1136] [68027.361123] SSL/TLS.
[rdpclient 1136] [68028.491924] SSL_ERROR_SSL
[rdpclient 1136] [68028.492038] [SSL] error:14094419:SSL routines:ssl3_read_bytes:tlsv1 alert access denied
[rdpclient 1136] [68028.492081] rdpclient-credssp.cpp ( 146): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 1136] [68028.492120] rdpclient-credssp.cpp ( 196): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [68028.492155] Final message: CredSSP connection failed.
[rdpclient 1136] [68028.492176] rdpclient-credssp.cpp ( 324): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 1136] [68028.492212] rdpclient-credssp.cpp ( 656): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 1136] [68028.492250] rdpclient-tcp.cpp ( 533): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 1136] [68028.492288] CredSSP connection failed.
[ rdpsnd] [68028.497537] Link lost.
[ pfac] [68028.497664] Process pid 1136 terminated, status 00000009.
[ gm] [68073.290977] Run '/sbin/resolver 0x8da6260 dns [TS-RDS01.domain.LOCAL]', log '', env '', pid ''.
[ pfac] [68073.291261] Run /sbin/resolver 0x8da6260 dns [TS-RDS01.domain.LOCAL].
[ pfac] [68073.291447] Ok, PID 1137.
[ gm] [68073.300425] TS-RDS01.domain.LOCAL => 10.99.99.171.
[ pfac] [68073.300583] Process pid 1137 terminated, status 00000000.
[ gm] [68073.300730] Free ram before fork terminal client /sbin/rdpclient-SSE (session 4): 2465408 Kb.
[ pfac] [68073.300768] Run /sbin/rdpclient-SSE 4.
[ gm] [68073.300790] Run '/sbin/rdpclient-SSE 4', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [68073.300866] Ok, PID 1138.
[rdpclient 1138] [68073.303127] RDP Terminal Client, WTware 5.4.98, pipe 4, pid 1138.
[ gm] [68073.303481] ERROR: usb-serial device 1c4f:0002 not found.
[rdpclient 1138] [68073.303507] Use /lib/ui32-SSE.so.
[ gm] [68073.303543] Do NOT redirect COM1.
[ gm] [68073.303579] ERROR: usb-serial device 1395:0025 not found.
[ gm] [68073.303614] Do NOT redirect COM2.
[ gm] [68073.303648] ERROR: usb-serial device 03f0:042a not found.
[ gm] [68073.303682] Do NOT redirect COM2.
[rdpclient 1138] [68073.303721] Add RDP printer redirection for "HP LaserJet Professional M1132 MFP".
[rdpclient 1138] [68073.303759] Redirect sound.
[rdpclient 1138] [68073.303835] Make RDP session with 10.99.99.171, port 3389.
[rdpclient 1138] [68073.303875] No username.
[rdpclient 1138] [68073.303912] No password.
[rdpclient 1138] [68073.303949] No PIN.
[rdpclient 1138] [68073.303986] Domain: "domain.local".
[rdpclient 1138] [68073.304046] No shell.
[rdpclient 1138] [68073.304083] No directory.
[rdpclient 1138] [68073.304120] Window: 1216x960@24.
[rdpclient 1138] [68073.304157] PFlags 0x0000002E.
[rdpclient 1138] [68073.304194] Keyboard 00000409:00000000.
[rdpclient 1138] [68073.304230] My hostname "ts1-client1".
[rdpclient 1138] [68073.304267] TCP: connecting to 10.99.99.171:3389.
[rdpclient 1138] [68073.310972] TCP: connection with 10.99.99.171:3389 established.
[rdpclient 1138] [68073.311065] Turn keepalive on.
[rdpclient 1138] [68073.311297] Free ram after buffers allocation: 2464664 KB.
[rdpclient 1138] [68073.311342] Use Balance Info 28 bytes: 'tsv://VMResource.1.POOL'.
[rdpclient 1138] [68087.912814] Reconnect with CredSSP enabled.
[rdpclient 1138] [68087.912882] TCP: reconnecting to 10.99.99.171:3389.
[rdpclient 1138] [68087.919968] TCP: connection with 10.99.99.171:3389 established.
[rdpclient 1138] [68087.920103] Turn keepalive on.
[rdpclient 1138] [68087.920184] Use Balance Info 28 bytes: 'tsv://VMResource.1.POOL'.
[rdpclient 1138] [68087.930054] Server supports GFX Pipeline.
[rdpclient 1138] [68087.930168] CredSSP.
[rdpclient 1138] [68087.930238] SSL/TLS.
[rdpclient 1138] [68088.079546] Enable font smoothing and Desktop Composition.
[rdpclient 1138] [68088.353031] TS_STATUS_FINDING_DESTINATION
[rdpclient 1138] [68088.483904] TS_STATUS_VM_LOADING
[rdpclient 1138] [68088.486946] TS_STATUS_LOADING_DESTINATION
[rdpclient 1138] [68088.498464] TS_STATUS_REDIRECTING_TO_DESTINATION
[rdpclient 1138] [68088.522191] TS_STATUS_BRINGING_SESSION_ONLINE
[rdpclient 1138] [68088.537445] TS_STATUS_VM_LOADING
[rdpclient 1138] [68088.617662] TS_STATUS_VM_BOOTING
[rdpclient 1138] [68207.708325] TS_STATUS_ 0x00000504.
[rdpclient 1138] [68209.985291] Server Redirection flags 0x00000b0d.
[ gm] [68209.985359] TSClient (sessionId 4, pid 1138) gracefully end.
[rdpclient 1138] [68209.985382] Server 10.10.100.83.
[rdpclient 1138] [68209.985420] User "user".
[rdpclient 1138] [68209.985459] Domain "domain".
[rdpclient 1138] [68209.985498] Send Disconnect Provider Ultimatum.
[ gm] [68209.985752] Free ram before fork terminal client /sbin/rdpclient-SSE (session 5): 2465260 Kb.
[ gm] [68209.985791] Run '/sbin/rdpclient-SSE 5', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [68209.985878] Run /sbin/rdpclient-SSE 5.
[ rdpsnd] [68209.985901] Link lost.
[ pfac] [68209.985992] Process pid 1138 terminated, status 00000009.
[ pfac] [68209.986060] Ok, PID 1140.
[rdpclient 1140] [68209.988435] RDP Terminal Client, WTware 5.4.98, pipe 5, pid 1140.
[rdpclient 1140] [68209.988896] Use /lib/ui32-SSE.so.
[ gm] [68209.988935] ERROR: usb-serial device 1c4f:0002 not found.
[ gm] [68209.988971] Do NOT redirect COM1.
[ gm] [68209.989006] ERROR: usb-serial device 1395:0025 not found.
[ gm] [68209.989040] Do NOT redirect COM2.
[ gm] [68209.989074] ERROR: usb-serial device 03f0:042a not found.
[ gm] [68209.989108] Do NOT redirect COM2.
[rdpclient 1140] [68209.989396] Add RDP printer redirection for "HP LaserJet Professional M1132 MFP".
[rdpclient 1140] [68209.989461] Redirect sound.
[rdpclient 1140] [68209.989607] Make RDP session with 10.10.100.83, port 3389.
[rdpclient 1140] [68209.989670] Username: "user".
[rdpclient 1140] [68209.989730] Password: present.
[rdpclient 1140] [68209.989792] No PIN.
[rdpclient 1140] [68209.989854] Domain: "domain".
[rdpclient 1140] [68209.989913] No shell.
[rdpclient 1140] [68209.989973] No directory.
[rdpclient 1140] [68209.990034] Window: 1216x960@24.
[rdpclient 1140] [68209.990102] PFlags 0x0000002E.
[rdpclient 1140] [68209.990165] Keyboard 00000409:00000000.
[rdpclient 1140] [68209.990225] My hostname "ts1-client1".
[rdpclient 1140] [68209.990287] TCP: connecting to 10.10.100.83:3389.
[rdpclient 1140] [68209.997073] TCP: connection with 10.10.100.83:3389 established.
[rdpclient 1140] [68209.997141] Turn keepalive on.
[rdpclient 1140] [68209.997550] Free ram after buffers allocation: 2465136 KB.
[rdpclient 1140] [68209.997625] Empty Balance Info.
[rdpclient 1140] [68210.442997] Reconnect with CredSSP enabled.
[rdpclient 1140] [68210.443144] TCP: reconnecting to 10.10.100.83:3389.
[rdpclient 1140] [68210.449945] TCP: connection with 10.10.100.83:3389 established.
[rdpclient 1140] [68210.450054] Turn keepalive on.
[rdpclient 1140] [68210.450133] Empty Balance Info.
[rdpclient 1140] [68210.935891] Server supports GFX Pipeline.
[rdpclient 1140] [68210.936040] CredSSP.
[rdpclient 1140] [68210.936105] SSL/TLS.
[rdpclient 1140] [68211.162100] Redirected Session ID 0x00000000.
[rdpclient 1140] [68211.319172] Enable font smoothing and Desktop Composition.
[rdpclient 1140] [68211.861562] RDP5 encryption (X.509).
[rdpclient 1140] [68213.556563] GFX codec.
[rdpclient 1140] [68222.599955] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000002.
[rdpclient 1140] [68222.633126] Run 3 tile threads.
[rdpclient 1140] [68226.297470] SessionId 0x00000002: domain\user.
[rdpclient 1140] [68604.457462] Sound version: 8.
[rdpclient 1140] [68604.457554] ADPCM sound compression.
[rdpclient 1140] [68604.457949] Sound redirection: 44100 frames per second.
[ KERNEL] [74290.801412] usb 5-1: new high-speed USB device number 5 using xhci_hcd
[ KERNEL] [74290.944214] usb 5-1: New USB device found, idVendor=03f0, idProduct=042a
[ KERNEL] [74290.944220] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ KERNEL] [74290.944224] usb 5-1: Product: HP LaserJet Professional M1132 MFP
[ KERNEL] [74290.944227] usb 5-1: Manufacturer: Hewlett-Packard
[ KERNEL] [74290.944230] usb 5-1: SerialNumber: 000000000QHA9HSFSI1c
[ KERNEL] [74290.945553] usb-storage 5-1:1.0: USB Mass Storage device detected
[ KERNEL] [74290.945704] scsi host4: usb-storage 5-1:1.0
[ KERNEL] [74292.717517] usb 5-1: USB disconnect, device number 5
[ KERNEL] [74293.209411] usb 5-1: new high-speed USB device number 6 using xhci_hcd
[ KERNEL] [74293.352100] usb 5-1: New USB device found, idVendor=03f0, idProduct=042a
[ KERNEL] [74293.352106] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ KERNEL] [74293.352110] usb 5-1: Product: HP LaserJet Professional M1132 MFP
[ KERNEL] [74293.352113] usb 5-1: Manufacturer: Hewlett-Packard
[ KERNEL] [74293.352116] usb 5-1: SerialNumber: 000000000QHA9HSFPR1a
[ KERNEL] [74293.356870] usblp 5-1:1.0: usblp0: USB Bidirectional printer dev 6 if 0 alt 0 proto 2 vid 0x03F0 pid 0x042A
[ gm] [79983.244194] [VNC] Connection from 10.10.100.47.
[ gm] [79983.254336] [VNC] Client VNC version 8 (RFB 003.008).
[ gm] [79988.259986] [VNC] Password ok.
[ gm] [79988.260075] [Syspopup] Activate VNC syspopup for 10.10.100.47.
[ gm] [80018.356974] [VNC] Timeout. Accept incoming connection.
[ gm] [80018.372081] [VNC] 12 encodings.
[ gm] [80018.372201] [VNC] Encoding 16.
[ gm] [80018.372266] [VNC] Encoding 1.
[ gm] [80018.372328] [VNC] Encoding 22.
[ gm] [80018.372389] [VNC] Encoding 21.
[ gm] [80018.372450] [VNC] Encoding 15.
[ gm] [80018.372511] [VNC] Encoding 6.
[ gm] [80018.372573] [VNC] Encoding 5.
[ gm] [80018.372634] [VNC] Encoding 2.
[ gm] [80018.372694] [VNC] Encoding 0.
[ gm] [80018.372755] [VNC] Encoding -314.
[ gm] [80018.372816] [VNC] Encoding -239.
[ gm] [80018.372878] [VNC] Encoding -223.
[ gm] [80018.408447] [VNC] bits-per-pixel 8, depth 8, big-endian false, true-colour false.
[ gm] [80018.408563] [VNC] red-max 0x0000, green-max 0x0000, blue-max 0x0000.
[ gm] [80018.408635] [VNC] red-shift 0, green-shift 0, blue-shift 0.
[ gm] [80018.408699] [VNC] WTware DOES NOT support 8 bit color. Use 16, 24 or 32 bit color.
[ gm] [80018.408760] [VNC] 32-bit server, 32-bit client.
[ gm] [80018.408828] vncserver.cpp ( 685): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [80018.408894] vncserver.cpp ( 686): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [80018.408958] vncserver.cpp ( 688): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [80018.409023] vncserver.cpp ( 689): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [80018.409097] vncserver.cpp ( 690): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [80018.409162] vncserver.cpp ( 691): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [80018.409226] vncserver.cpp ( 692): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [80018.409289] vncserver.cpp ( 693): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [80018.576577] [VNC] 12 encodings.
[ gm] [80018.576675] [VNC] Encoding 15.
[ gm] [80018.576741] [VNC] Encoding 1.
[ gm] [80018.576805] [VNC] Encoding 5.
[ gm] [80018.576867] [VNC] Encoding 22.
[ gm] [80018.576929] [VNC] Encoding 21.
[ gm] [80018.576991] [VNC] Encoding 16.
[ gm] [80018.577052] [VNC] Encoding 6.
[ gm] [80018.577115] [VNC] Encoding 2.
[ gm] [80018.577176] [VNC] Encoding 0.
[ gm] [80018.577238] [VNC] Encoding -314.
[ gm] [80018.577300] [VNC] Encoding -239.
[ gm] [80018.577363] [VNC] Encoding -223.
[ gm] [80018.580841] [VNC] bits-per-pixel 32, depth 24, big-endian false, true-colour true.
[ gm] [80018.580957] [VNC] red-max 0x00ff, green-max 0x00ff, blue-max 0x00ff.
[ gm] [80018.581023] [VNC] red-shift 16, green-shift 8, blue-shift 0.
[ gm] [80018.581086] [VNC] 32-bit server, 32-bit client.
[ gm] [80026.951904] [VNC] Close connection.
[ gm] [90746.736110] [VNC] Connection from 10.12.81.81.
[ gm] [90746.743562] [VNC] Client VNC version 8 (RFB 003.008).
[ gm] [90750.658699] [VNC] Password ok.
[ gm] [90750.658770] [Syspopup] Activate VNC syspopup for 10.12.81.81.
[ gm] [90760.826101] [VNC] 12 encodings.
[ gm] [90760.826217] [VNC] Encoding 16.
[ gm] [90760.826282] [VNC] Encoding 1.
[ gm] [90760.826345] [VNC] Encoding 22.
[ gm] [90760.826406] [VNC] Encoding 21.
[ gm] [90760.826467] [VNC] Encoding 15.
[ gm] [90760.826529] [VNC] Encoding 6.
[ gm] [90760.826590] [VNC] Encoding 5.
[ gm] [90760.826650] [VNC] Encoding 2.
[ gm] [90760.826712] [VNC] Encoding 0.
[ gm] [90760.826773] [VNC] Encoding -314.
[ gm] [90760.826835] [VNC] Encoding -239.
[ gm] [90760.826895] [VNC] Encoding -223.
[ gm] [90760.844537] [VNC] bits-per-pixel 8, depth 6, big-endian false, true-colour true.
[ gm] [90760.844653] [VNC] red-max 0x0003, green-max 0x0003, blue-max 0x0003.
[ gm] [90760.844718] [VNC] red-shift 4, green-shift 2, blue-shift 0.
[ gm] [90760.844780] [VNC] WTware DOES NOT support 8 bit color. Use 16, 24 or 32 bit color.
[ gm] [90760.844851] [VNC] 32-bit server, 32-bit client.
[ gm] [90760.844918] vncserver.cpp ( 685): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [90760.844983] vncserver.cpp ( 686): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [90760.845048] vncserver.cpp ( 689): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [90760.845112] vncserver.cpp ( 690): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [90760.845176] vncserver.cpp ( 691): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [90760.845240] vncserver.cpp ( 692): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [90760.845303] vncserver.cpp ( 693): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [90761.021269] [VNC] 12 encodings.
[ gm] [90761.021383] [VNC] Encoding 15.
[ gm] [90761.021448] [VNC] Encoding 1.
[ gm] [90761.021510] [VNC] Encoding 5.
[ gm] [90761.021582] [VNC] Encoding 22.
[ gm] [90761.021644] [VNC] Encoding 21.
[ gm] [90761.021705] [VNC] Encoding 16.
[ gm] [90761.021768] [VNC] Encoding 6.
[ gm] [90761.021829] [VNC] Encoding 2.
[ gm] [90761.021890] [VNC] Encoding 0.
[ gm] [90761.021951] [VNC] Encoding -314.
[ gm] [90761.022014] [VNC] Encoding -239.
[ gm] [90761.022075] [VNC] Encoding -223.
[ gm] [90761.023922] [VNC] bits-per-pixel 32, depth 24, big-endian false, true-colour true.
[ gm] [90761.024081] [VNC] red-max 0x00ff, green-max 0x00ff, blue-max 0x00ff.
[ gm] [90761.024150] [VNC] red-shift 16, green-shift 8, blue-shift 0.
[ gm] [90761.024214] [VNC] 32-bit server, 32-bit client.
[ gm] [91262.885538] [VNC] Unknown keysym 0xffae.
[ gm] [91263.021320] [VNC] Unknown keysym 0xffae.
[SANED] saned started, PID 1173.
[SYSLOG] <31>Jul 25 15:31:28 saned[1173]: saned (IPv4 only) from sane-backends 1.0.25 starting up
[SYSLOG] <31>Jul 25 15:31:28 saned[1173]: check_host: access by remote host: 10.10.100.83
[SYSLOG] <31>Jul 25 15:31:28 saned[1173]: init: access granted to PCUSER@10.10.100.83
[SYSLOG] <31>Jul 25 15:31:34 saned[1173]: saned exiting
[SANED] close kotopipe (n = 0, errno 11).
[ rdpsnd] [91426.816418] ALSA: pcm_hw.c:565:(snd_pcm_hw_hwsync) SNDRV_PCM_IOCTL_HWSYNC failed (-32): Broken pipe
[ rdpsnd] [91426.816512] ALSA: Stopped: underrun (playback) or overrun (capture) detected.
[SANED] saned started, PID 1186.
[SYSLOG] <31>Jul 25 15:50:57 saned[1186]: saned (IPv4 only) from sane-backends 1.0.25 starting up
[SYSLOG] <31>Jul 25 15:50:57 saned[1186]: check_host: access by remote host: 10.10.100.83
[SYSLOG] <31>Jul 25 15:50:57 saned[1186]: init: access granted to PCUSER@10.10.100.83
[SYSLOG] <31>Jul 25 15:51:01 saned[1186]: saned exiting
