Сканер Symbol 2208 [USB/COM]
Добавлено: Пт апр 22, 2011 12:02 pm
Задача: заставить Symbol 2208 работать на терминале из под WTware именно через режим эмуляции COM порта. Сканер в данный режим переведен. WTware PRO 4.4.15. Лог терминала прилагаю. Прошу Вашего совета и помощи в реализации...
| +--- FILE "/proc/bus/usb/devices" -----------------------
| | T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
| | B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
| | D: Ver= 1.00 Cls=09(hub ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
| | P: Vendor=0000 ProdID=0000 Rev= 0.00
| | S: Product=USB UHCI Root Hub
| | S: SerialNumber=a000
| | C:* #Ifs= 1 Cfg#= 1 Atr=40 MxPwr= 0mA
| | I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
| | E: Ad=81(I) Atr=03(Int.) MxPS= 8 Ivl=255ms
| | T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
| | S: SerialNumber=9800
| | T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
| | S: SerialNumber=9400
| | T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
| | S: SerialNumber=9000
| | T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=12 MxCh= 0
| | D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=16 #Cfgs= 1
| | P: Vendor=05e0 ProdID=0600 Rev= 2.01
| | S: Manufacturer=?Symbol Technologies, Inc, 2002
| | S: Product=Symbol Bar Code Scanner
| | S: SerialNumber=S/N:C92B41B28232 Rev:NBRMIAAT5
| | C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=400mA
| | I: If#= 0 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=01 Driver=(none)
| | E: Ad=82(I) Atr=03(Int.) MxPS= 64 Ivl=10ms
| initrd: Found USB device 05e0:0600.
| initrd: Found USB keyboard.
| initrd: Loading usb Human Interface Device driver.
| initrd: +--- Executing "/sbin/insmod input"
| | Using /lib/modules/2.4.36/kernel/drivers/input/input.o
| initrd: +--- Executing "/sbin/insmod hid"
| KERNEL: usb.c: registered new driver hid
| KERNEL: : USB HID v1.10 Device [?Symbol Technologies, Inc, 2002 Symbol Bar Code Scanner] on usb1:2.0
| KERNEL: hid-core.c: v1.8.1 Andreas Gal, Vojtech Pavlik <vojtech@suse.cz>
| KERNEL: hid-core.c: USB HID support drivers
| | Using /lib/modules/2.4.36/kernel/drivers/usb/hid.o
| initrd: Loading usb keyboard driver.
| initrd: +--- Executing "/sbin/insmod keybdev"
| | Using /lib/modules/2.4.36/kernel/drivers/input/keybdev.o
| initrd: Loading ethernet drivers.
| initrd: +--- Executing "/sbin/modprobe atl2"
| KERNEL: Atheros(R) L2 Ethernet Network Driver - version 1.0.40.3
| KERNEL: Copyright (c) 2007 Atheros Corporation.
| KERNEL: PCI: Setting latency timer of device 02:00.0 to 64
