Есть ферма 2012R2 RDS VDI - если на брокераз добавляю в реестр
DefaultTsvUrl - tsv://VMResource.1.VDI
и прописываю в соединении адрес кластера брокеров - то падает с ошибкой.
Если указываю адреса терминальных серверов - то подключение VDI происходит, но медленно - сначала происходит логинит на один терминал, он перекидывает уже на VDI терминал.
Можно как то решить ?
WTware v.5.2.38
WTware v.5.2.38 supervisor.
WTC listener is active.
HTTPd listener is active.
[KERNEL] [ 0.000000] Linux version 3.14.48 (root@c12) (gcc version 4.9.2 (Ubuntu 4.9.2-10ubuntu13) ) #1 PREEMPT Sat Jul 18 22:43:09 SAMT 2015
[KERNEL] [ 0.000000] KERNEL supported cpus:
[KERNEL] [ 0.000000] Intel GenuineIntel
[KERNEL] [ 0.000000] AMD AuthenticAMD
[KERNEL] [ 0.000000] NSC Geode by NSC
[KERNEL] [ 0.000000] Cyrix CyrixInstead
[KERNEL] [ 0.000000] Centaur CentaurHauls
[KERNEL] [ 0.000000] Disabled fast string operations
[KERNEL] [ 0.000000] e820: BIOS-provided physical RAM map:
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001f6dffff] usable
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000001f6e0000-0x000000001f6e2fff] ACPI NVS
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000001f6e3000-0x000000001f6effff] ACPI data
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000001f6f0000-0x000000001f6fffff] reserved
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000ffb00000-0x00000000ffffffff] reserved
[KERNEL] [ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[KERNEL] [ 0.000000] DMI not present or invalid.
[KERNEL] [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[KERNEL] [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[KERNEL] [ 0.000000] e820: last_pfn = 0x1f6e0 max_arch_pfn = 0x100000
[KERNEL] [ 0.000000] MTRR default type: uncachable
[KERNEL] [ 0.000000] MTRR fixed ranges enabled:
[KERNEL] [ 0.000000] 00000-9FFFF write-back
[KERNEL] [ 0.000000] A0000-EFFFF uncachable
[KERNEL] [ 0.000000] F0000-FFFFF write-through
[KERNEL] [ 0.000000] MTRR variable ranges enabled:
[KERNEL] [ 0.000000] 0 base 000000000 mask FE0000000 write-back
[KERNEL] [ 0.000000] 1 base 01F800000 mask FFF800000 uncachable
[KERNEL] [ 0.000000] 2 base 01F700000 mask FFFF00000 write-through
[KERNEL] [ 0.000000] 3 disabled
[KERNEL] [ 0.000000] 4 disabled
[KERNEL] [ 0.000000] 5 disabled
[KERNEL] [ 0.000000] 6 disabled
[KERNEL] [ 0.000000] 7 disabled
[KERNEL] [ 0.000000] found SMP MP-table at [mem 0x000f44b0-0x000f44bf] mapped at [c00f44b0]
[KERNEL] [ 0.000000] initial memory mapped: [mem 0x00000000-0x007fffff]
[KERNEL] [ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[KERNEL] [ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[KERNEL] [ 0.000000] [mem 0x00000000-0x000fffff] page 4k
[KERNEL] [ 0.000000] init_memory_mapping: [mem 0x1ec00000-0x1effffff]
[KERNEL] [ 0.000000] [mem 0x1ec00000-0x1effffff] page 2M
[KERNEL] [ 0.000000] init_memory_mapping: [mem 0x18000000-0x1ebfffff]
[KERNEL] [ 0.000000] [mem 0x18000000-0x1ebfffff] page 2M
[KERNEL] [ 0.000000] init_memory_mapping: [mem 0x00100000-0x17ffffff]
[KERNEL] [ 0.000000] [mem 0x00100000-0x003fffff] page 4k
[KERNEL] [ 0.000000] [mem 0x00400000-0x17ffffff] page 2M
[KERNEL] [ 0.000000] init_memory_mapping: [mem 0x1f000000-0x1f6dffff]
[KERNEL] [ 0.000000] [mem 0x1f000000-0x1f3fffff] page 2M
[KERNEL] [ 0.000000] [mem 0x1f400000-0x1f6dffff] page 4k
[KERNEL] [ 0.000000] BRK [0x005ad000, 0x005adfff] PGTABLE
[KERNEL] [ 0.000000] early_memtest: # of tests: 1
[KERNEL] [ 0.000000] 0000010000 - 000009b000 pattern 0000000000000000
[KERNEL] [ 0.000000] 00005b3000 - 001f3b2000 pattern 0000000000000000
[KERNEL] [ 0.000000] 001f6bf000 - 001f6e0000 pattern 0000000000000000
[KERNEL] [ 0.000000] RAMDISK: [mem 0x1f3b2000-0x1f6befff]
[KERNEL] [ 0.000000] ACPI: RSDP 0x00000000000F6530 000014 (v00 IntelR)
[KERNEL] [ 0.000000] ACPI: RSDT 0x000000001F6E3040 000030 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[KERNEL] [ 0.000000] ACPI: FACP 0x000000001F6E30C0 000074 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[KERNEL] [ 0.000000] ACPI: DSDT 0x000000001F6E3180 004050 (v01 INTELR AWRDACPI 00001000 MSFT 0100000E)
[KERNEL] [ 0.000000] ACPI: FACS 0x000000001F6E0000 000040
[KERNEL] [ 0.000000] ACPI: MCFG 0x000000001F6E7300 00003C (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[KERNEL] [ 0.000000] ACPI: APIC 0x000000001F6E7240 00005A (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[KERNEL] [ 0.000000] ACPI: Local APIC address 0xfee00000
[KERNEL] [ 0.000000] 502MB LOWMEM available.
[KERNEL] [ 0.000000] mapped low ram: 0 - 1f6e0000
[KERNEL] [ 0.000000] low ram: 0 - 1f6e0000
[KERNEL] [ 0.000000] Zone ranges:
[KERNEL] [ 0.000000] DMA [mem 0x00001000-0x00ffffff]
[KERNEL] [ 0.000000] Normal [mem 0x01000000-0x1f6dffff]
[KERNEL] [ 0.000000] Movable zone start for each node
[KERNEL] [ 0.000000] Early memory node ranges
[KERNEL] [ 0.000000] node 0: [mem 0x00001000-0x0009efff]
[KERNEL] [ 0.000000] node 0: [mem 0x00100000-0x1f6dffff]
[KERNEL] [ 0.000000] On node 0 totalpages: 128638
[KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat c0519600, node_mem_map defc2020
[KERNEL] [ 0.000000] DMA zone: 32 pages used for memmap
[KERNEL] [ 0.000000] DMA zone: 0 pages reserved
[KERNEL] [ 0.000000] DMA zone: 3998 pages, LIFO batch:0
[KERNEL] [ 0.000000] Normal zone: 974 pages used for memmap
[KERNEL] [ 0.000000] Normal zone: 124640 pages, LIFO batch:31
[KERNEL] [ 0.000000] Using APIC driver default
[KERNEL] [ 0.000000] ACPI: PM-Timer IO Port: 0x408
[KERNEL] [ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[KERNEL] [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[KERNEL] [ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[KERNEL] [ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[KERNEL] [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[KERNEL] [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[KERNEL] [ 0.000000] ACPI: IRQ0 used by override.
[KERNEL] [ 0.000000] ACPI: IRQ2 used by override.
[KERNEL] [ 0.000000] ACPI: IRQ9 used by override.
[KERNEL] [ 0.000000] Using ACPI (MADT) for SMP configuration information
[KERNEL] [ 0.000000] nr_irqs_gsi: 40
[KERNEL] [ 0.000000] e820: [mem 0x20000000-0xdfffffff] available for PCI devices
[KERNEL] [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[KERNEL] [ 0.000000] pcpu-alloc: [0] 0
[KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 127632
[KERNEL] [ 0.000000] Kernel command line: root=/dev/ram0 memtest=1 quiet initrd=packages/initrd BOOT_IMAGE=packages/kernel
[KERNEL] [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[KERNEL] [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[KERNEL] [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[KERNEL] [ 0.000000] Initializing CPU#0
[KERNEL] [ 0.000000] allocated 1029880 bytes of page_cgroup
[KERNEL] [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[KERNEL] [ 0.000000] Memory: 501064K/514552K available (3169K kernel code, 211K rwdata, 828K rodata, 316K init, 248K bss, 13488K reserved)
[KERNEL] [ 0.000000] virtual kernel memory layout:
[KERNEL] [ 0.000000] fixmap : 0xfffa2000 - 0xfffff000 ( 372 kB)
[KERNEL] [ 0.000000] vmalloc : 0xdfee0000 - 0xfffa0000 ( 512 MB)
[KERNEL] [ 0.000000] lowmem : 0xc0000000 - 0xdf6e0000 ( 502 MB)
[KERNEL] [ 0.000000] .init : 0xc051e000 - 0xc056d000 ( 316 kB)
[KERNEL] [ 0.000000] .data : 0xc04189f2 - 0xc051dd00 (1044 kB)
[KERNEL] [ 0.000000] .text : 0xc0100000 - 0xc04189f2 (3170 kB)
[KERNEL] [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[KERNEL] [ 0.000000] Preemptible hierarchical RCU implementation.
[KERNEL] [ 0.000000] NR_IRQS:2304 nr_irqs:256 16
[KERNEL] [ 0.000000] CPU 0 irqstacks, hard=de808000 soft=de80a000
[KERNEL] [ 0.000000] Console: colour VGA+ 80x25
[KERNEL] [ 0.000000] console [tty0] enabled
[KERNEL] [ 0.000000] tsc: Fast TSC calibration using PIT
[KERNEL] [ 0.000000] tsc: Detected 997.533 MHz processor
[KERNEL] [ 0.001017] Calibrating delay loop (skipped), value calculated using timer frequency.. 1995.06 BogoMIPS (lpj=997533)
[KERNEL] [ 0.001028] pid_max: default: 32768 minimum: 301
[KERNEL] [ 0.001064] ACPI: Core revision 20131218
[KERNEL] [ 0.006162] ACPI: All ACPI Tables successfully acquired
[KERNEL] [ 0.007084] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[KERNEL] [ 0.007093] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[KERNEL] [ 0.007440] Initializing cgroup subsys memory
[KERNEL] [ 0.007498] Disabled fast string operations
[KERNEL] [ 0.007537] Last level iTLB entries: 4KB 128, 2MB 0, 4MB 2
[KERNEL] [ 0.007537] Last level dTLB entries: 4KB 128, 2MB 0, 4MB 8, 1GB 0
[KERNEL] [ 0.007537] tlb_flushall_shift: 6
[KERNEL] [ 0.007544] CPU: Intel(R) Celeron(R) M processor 1.00GHz (fam: 06, model: 0d, stepping: 08)
[KERNEL] [ 0.008048] Performance Events: p6 PMU driver.
[KERNEL] [ 0.008068] ... version: 0
[KERNEL] [ 0.008075] ... bit width: 32
[KERNEL] [ 0.008078] ... generic registers: 2
[KERNEL] [ 0.008081] ... value mask: 00000000ffffffff
[KERNEL] [ 0.008085] ... max period: 000000007fffffff
[KERNEL] [ 0.008087] ... fixed-purpose events: 0
[KERNEL] [ 0.008091] ... event mask: 0000000000000003
[KERNEL] [ 0.008537] Enabling APIC mode: Flat. Using 1 I/O APICs
[KERNEL] [ 0.008957] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[KERNEL] [ 0.019000] devtmpfs: initialized
[KERNEL] [ 0.019000] PM: Registering ACPI NVS region [mem 0x1f6e0000-0x1f6e2fff] (12288 bytes)
[KERNEL] [ 0.019227] NET: Registered protocol family 16
[KERNEL] [ 0.020780] cpuidle: using governor ladder
[KERNEL] [ 0.020791] cpuidle: using governor menu
[KERNEL] [ 0.020911] ACPI: bus type PCI registered
[KERNEL] [ 0.020941] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[KERNEL] [ 0.020949] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[KERNEL] [ 0.020953] PCI: Using MMCONFIG for extended config space
[KERNEL] [ 0.020956] PCI: Using configuration type 1 for base access
[KERNEL] [ 0.037300] bio: create slab at 0
[KERNEL] [ 0.037750] ACPI: Added _OSI(Module Device)
[KERNEL] [ 0.037761] ACPI: Added _OSI(Processor Device)
[KERNEL] [ 0.037765] ACPI: Added _OSI(3.0 _SCP Extensions)
[KERNEL] [ 0.037769] ACPI: Added _OSI(Processor Aggregator Device)
[KERNEL] [ 0.045686] ACPI: Interpreter enabled
[KERNEL] [ 0.045708] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S1_] (20131218/hwxface-580)
[KERNEL] [ 0.045719] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20131218/hwxface-580)
[KERNEL] [ 0.045749] ACPI: (supports S0 S3 S5)
[KERNEL] [ 0.045754] ACPI: Using IOAPIC for interrupt routing
[KERNEL] [ 0.045976] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[KERNEL] [ 0.077080] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[KERNEL] [ 0.077109] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments]
[KERNEL] [ 0.077126] acpi PNP0A08:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[KERNEL] [ 0.077650] PCI host bridge to bus 0000:00
[KERNEL] [ 0.077669] pci_bus 0000:00: root bus resource [bus 00-ff]
[KERNEL] [ 0.077678] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[KERNEL] [ 0.077684] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[KERNEL] [ 0.077690] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[KERNEL] [ 0.077695] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff]
[KERNEL] [ 0.077701] pci_bus 0000:00: root bus resource [mem 0x1f700000-0xfebfffff]
[KERNEL] [ 0.077727] pci 0000:00:00.0: [8086:2590] type 00 class 0x060000
[KERNEL] [ 0.078157] pci 0000:00:02.0: [8086:2592] type 00 class 0x030000
[KERNEL] [ 0.078185] pci 0000:00:02.0: reg 0x10: [mem 0xd0100000-0xd017ffff]
[KERNEL] [ 0.078196] pci 0000:00:02.0: reg 0x14: [io 0xda00-0xda07]
[KERNEL] [ 0.078207] pci 0000:00:02.0: reg 0x18: [mem 0xc0000000-0xcfffffff pref]
[KERNEL] [ 0.078218] pci 0000:00:02.0: reg 0x1c: [mem 0xd0180000-0xd01bffff]
[KERNEL] [ 0.078636] pci 0000:00:1d.0: [8086:2658] type 00 class 0x0c0300
[KERNEL] [ 0.078697] pci 0000:00:1d.0: reg 0x20: [io 0xdb00-0xdb1f]
[KERNEL] [ 0.078866] pci 0000:00:1d.0: System wakeup disabled by ACPI
[KERNEL] [ 0.079169] pci 0000:00:1d.1: [8086:2659] type 00 class 0x0c0300
[KERNEL] [ 0.079230] pci 0000:00:1d.1: reg 0x20: [io 0xdd00-0xdd1f]
[KERNEL] [ 0.079397] pci 0000:00:1d.1: System wakeup disabled by ACPI
[KERNEL] [ 0.079662] pci 0000:00:1d.2: [8086:265a] type 00 class 0x0c0300
[KERNEL] [ 0.079723] pci 0000:00:1d.2: reg 0x20: [io 0xd800-0xd81f]
[KERNEL] [ 0.079891] pci 0000:00:1d.2: System wakeup disabled by ACPI
[KERNEL] [ 0.080212] pci 0000:00:1d.3: [8086:265b] type 00 class 0x0c0300
[KERNEL] [ 0.080273] pci 0000:00:1d.3: reg 0x20: [io 0xd900-0xd91f]
[KERNEL] [ 0.080450] pci 0000:00:1d.3: System wakeup disabled by ACPI
[KERNEL] [ 0.080730] pci 0000:00:1d.7: [8086:265c] type 00 class 0x0c0320
[KERNEL] [ 0.080765] pci 0000:00:1d.7: reg 0x10: [mem 0xd01c0000-0xd01c03ff]
[KERNEL] [ 0.080852] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[KERNEL] [ 0.081019] pci 0000:00:1d.7: System wakeup disabled by ACPI
[KERNEL] [ 0.081288] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401
[KERNEL] [ 0.081498] pci 0000:00:1e.0: System wakeup disabled by ACPI
[KERNEL] [ 0.081764] pci 0000:00:1e.2: [8086:266e] type 00 class 0x040100
[KERNEL] [ 0.081796] pci 0000:00:1e.2: reg 0x10: [io 0xd000-0xd0ff]
[KERNEL] [ 0.081809] pci 0000:00:1e.2: reg 0x14: [io 0xdc00-0xdc3f]
[KERNEL] [ 0.081823] pci 0000:00:1e.2: reg 0x18: [mem 0xd01c1000-0xd01c11ff]
[KERNEL] [ 0.081835] pci 0000:00:1e.2: reg 0x1c: [mem 0xd01c2000-0xd01c20ff]
[KERNEL] [ 0.081890] pci 0000:00:1e.2: PME# supported from D0 D3hot D3cold
[KERNEL] [ 0.082053] pci 0000:00:1e.2: System wakeup disabled by ACPI
[KERNEL] [ 0.082324] pci 0000:00:1f.0: [8086:2641] type 00 class 0x060100
[KERNEL] [ 0.082430] pci 0000:00:1f.0: address space collision: [io 0x0400-0x047f] conflicts with ACPI PM1a_EVT_BLK [??? 0x00000400-0x00000403 flags 0x80000000]
[KERNEL] [ 0.082441] pci 0000:00:1f.0: quirk: [io 0x0480-0x04bf] claimed by ICH6 GPIO
[KERNEL] [ 0.082449] pci 0000:00:1f.0: LPC Generic IO decode 1 PIO at 0280-02ff
[KERNEL] [ 0.082456] pci 0000:00:1f.0: LPC Generic IO decode 2 PIO at 0290-029f
[KERNEL] [ 0.082811] pci 0000:00:1f.2: [8086:2653] type 00 class 0x010180
[KERNEL] [ 0.082840] pci 0000:00:1f.2: reg 0x10: [io 0x0000-0x0007]
[KERNEL] [ 0.082853] pci 0000:00:1f.2: reg 0x14: [io 0x0000-0x0003]
[KERNEL] [ 0.082865] pci 0000:00:1f.2: reg 0x18: [io 0x0000-0x0007]
[KERNEL] [ 0.082878] pci 0000:00:1f.2: reg 0x1c: [io 0x0000-0x0003]
[KERNEL] [ 0.082890] pci 0000:00:1f.2: reg 0x20: [io 0xf000-0xf00f]
[KERNEL] [ 0.082936] pci 0000:00:1f.2: PME# supported from D3hot
[KERNEL] [ 0.083369] pci 0000:00:1f.3: [8086:266a] type 00 class 0x0c0500
[KERNEL] [ 0.083439] pci 0000:00:1f.3: reg 0x20: [io 0x0500-0x051f]
[KERNEL] [ 0.084076] pci 0000:01:01.0: [10ec:8139] type 00 class 0x020000
[KERNEL] [ 0.084112] pci 0000:01:01.0: reg 0x10: [io 0xc000-0xc0ff]
[KERNEL] [ 0.084130] pci 0000:01:01.0: reg 0x14: [mem 0xd0011000-0xd00110ff]
[KERNEL] [ 0.084182] pci 0000:01:01.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[KERNEL] [ 0.084216] pci 0000:01:01.0: supports D1 D2
[KERNEL] [ 0.084223] pci 0000:01:01.0: PME# supported from D1 D2 D3hot D3cold
[KERNEL] [ 0.084514] pci 0000:01:02.0: [10ec:8139] type 00 class 0x020000
[KERNEL] [ 0.084549] pci 0000:01:02.0: reg 0x10: [io 0xc400-0xc4ff]
[KERNEL] [ 0.084565] pci 0000:01:02.0: reg 0x14: [mem 0xd0010000-0xd00100ff]
[KERNEL] [ 0.084617] pci 0000:01:02.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[KERNEL] [ 0.084653] pci 0000:01:02.0: supports D1 D2
[KERNEL] [ 0.084658] pci 0000:01:02.0: PME# supported from D1 D2 D3hot D3cold
[KERNEL] [ 0.084965] pci 0000:00:1e.0: PCI bridge to [bus 01] (subtractive decode)
[KERNEL] [ 0.084980] pci 0000:00:1e.0: bridge window [io 0xc000-0xcfff]
[KERNEL] [ 0.085014] pci 0000:00:1e.0: bridge window [mem 0xd0000000-0xd00fffff]
[KERNEL] [ 0.085028] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[KERNEL] [ 0.085034] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[KERNEL] [ 0.085040] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[KERNEL] [ 0.085046] pci 0000:00:1e.0: bridge window [mem 0x000c0000-0x000dffff] (subtractive decode)
[KERNEL] [ 0.085052] pci 0000:00:1e.0: bridge window [mem 0x1f700000-0xfebfffff] (subtractive decode)
[KERNEL] [ 0.085069] pci_bus 0000:00: on NUMA node 0
[KERNEL] [ 0.087151] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 *10 11 12 14 15)
[KERNEL] [ 0.087376] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12 *14 15)
[KERNEL] [ 0.087588] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 9 10 11 *12 14 15)
[KERNEL] [ 0.087806] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[KERNEL] [ 0.088105] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[KERNEL] [ 0.088340] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[KERNEL] [ 0.088553] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[KERNEL] [ 0.088766] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[KERNEL] [ 0.089645] ACPI: bus type USB registered
[KERNEL] [ 0.089988] usbcore: registered new interface driver usbfs
[KERNEL] [ 0.090220] usbcore: registered new interface driver hub
[KERNEL] [ 0.090429] usbcore: registered new device driver usb
[KERNEL] [ 0.091558] wmi: Mapper loaded
[KERNEL] [ 0.091571] PCI: Using ACPI for IRQ routing
[KERNEL] [ 0.098855] PCI: pci_cache_line_size set to 64 bytes
[KERNEL] [ 0.098919] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[KERNEL] [ 0.098927] e820: reserve RAM buffer [mem 0x1f6e0000-0x1fffffff]
[KERNEL] [ 0.100182] cfg80211: Calling CRDA to update world regulatory domain
[KERNEL] [ 0.100443] Switched to clocksource refined-jiffies
[KERNEL] [ 0.100734] pnp: PnP ACPI init
[KERNEL] [ 0.100776] ACPI: bus type PNP registered
[KERNEL] [ 0.101332] system 00:00: [io 0x04d0-0x04d1] has been reserved
[KERNEL] [ 0.101345] system 00:00: [io 0x0290-0x029f] has been reserved
[KERNEL] [ 0.101351] system 00:00: [io 0x02e0-0x035f] has been reserved
[KERNEL] [ 0.101359] system 00:00: [io 0x0290-0x0297] has been reserved
[KERNEL] [ 0.101370] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[KERNEL] [ 0.101431] pnp 00:01: [dma 4]
[KERNEL] [ 0.101653] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
[KERNEL] [ 0.101947] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[KERNEL] [ 0.102257] pnp 00:03: Plug and Play ACPI device, IDs PNP0800 (active)
[KERNEL] [ 0.102550] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[KERNEL] [ 0.103181] ACPI: IRQ 4 override to edge, high
[KERNEL] [ 0.103471] pnp 00:05: Plug and Play ACPI device, IDs PNP0501 (active)
[KERNEL] [ 0.104100] ACPI: IRQ 4 override to edge, high
[KERNEL] [ 0.104381] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
[KERNEL] [ 0.105142] ACPI: IRQ 4 override to edge, high
[KERNEL] [ 0.105432] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[KERNEL] [ 0.105985] ACPI: IRQ 4 override to edge, high
[KERNEL] [ 0.106342] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[KERNEL] [ 0.107626] pnp 00:09: Plug and Play ACPI device, IDs PNP0400 (active)
[KERNEL] [ 0.108412] system 00:0a: [io 0x0400-0x04bf] could not be reserved
[KERNEL] [ 0.108428] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[KERNEL] [ 0.108767] pnp 00:0b: Plug and Play ACPI device, IDs INT0800 (active)
[KERNEL] [ 0.109807] system 00:0c: [mem 0xe0000000-0xefffffff] has been reserved
[KERNEL] [ 0.109825] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[KERNEL] [ 0.110549] system 00:0d: [mem 0x000d1000-0x000d3fff] has been reserved
[KERNEL] [ 0.110562] system 00:0d: [mem 0x000f0000-0x000f7fff] could not be reserved
[KERNEL] [ 0.110568] system 00:0d: [mem 0x000f8000-0x000fbfff] could not be reserved
[KERNEL] [ 0.110574] system 00:0d: [mem 0x000fc000-0x000fffff] could not be reserved
[KERNEL] [ 0.110580] system 00:0d: [mem 0x1f6e0000-0x1f6fffff] could not be reserved
[KERNEL] [ 0.110587] system 00:0d: [mem 0x00000000-0x0009ffff] could not be reserved
[KERNEL] [ 0.110593] system 00:0d: [mem 0x00100000-0x1f6dffff] could not be reserved
[KERNEL] [ 0.110600] system 00:0d: [mem 0xfec00000-0xfec00fff] could not be reserved
[KERNEL] [ 0.110606] system 00:0d: [mem 0xfed13000-0xfed1dfff] has been reserved
[KERNEL] [ 0.110612] system 00:0d: [mem 0xfed20000-0xfed8ffff] has been reserved
[KERNEL] [ 0.110618] system 00:0d: [mem 0xfee00000-0xfee00fff] has been reserved
[KERNEL] [ 0.110624] system 00:0d: [mem 0xffb00000-0xffb7ffff] has been reserved
[KERNEL] [ 0.110637] system 00:0d: [mem 0xfff00000-0xffffffff] has been reserved
[KERNEL] [ 0.110643] system 00:0d: [mem 0x000e0000-0x000effff] has been reserved
[KERNEL] [ 0.110653] system 00:0d: Plug and Play ACPI device, IDs PNP0c01 (active)
[KERNEL] [ 0.110684] pnp: PnP ACPI: found 14 devices
[KERNEL] [ 0.110689] ACPI: bus type PNP unregistered
[KERNEL] [ 0.163167] Switched to clocksource acpi_pm
[KERNEL] [ 0.163217] pci 0000:00:1f.0: BAR 7: [io 0x0400-0x047f] has bogus alignment
[KERNEL] [ 0.163235] pci 0000:00:1e.0: BAR 9: assigned [mem 0x1f700000-0x1f7fffff pref]
[KERNEL] [ 0.163247] pci 0000:01:01.0: BAR 6: assigned [mem 0x1f700000-0x1f70ffff pref]
[KERNEL] [ 0.163255] pci 0000:01:02.0: BAR 6: assigned [mem 0x1f710000-0x1f71ffff pref]
[KERNEL] [ 0.163261] pci 0000:00:1e.0: PCI bridge to [bus 01]
[KERNEL] [ 0.163268] pci 0000:00:1e.0: bridge window [io 0xc000-0xcfff]
[KERNEL] [ 0.163278] pci 0000:00:1e.0: bridge window [mem 0xd0000000-0xd00fffff]
[KERNEL] [ 0.163287] pci 0000:00:1e.0: bridge window [mem 0x1f700000-0x1f7fffff pref]
[KERNEL] [ 0.163298] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[KERNEL] [ 0.163304] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[KERNEL] [ 0.163310] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[KERNEL] [ 0.163316] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000dffff]
[KERNEL] [ 0.163322] pci_bus 0000:00: resource 8 [mem 0x1f700000-0xfebfffff]
[KERNEL] [ 0.163328] pci_bus 0000:01: resource 0 [io 0xc000-0xcfff]
[KERNEL] [ 0.163333] pci_bus 0000:01: resource 1 [mem 0xd0000000-0xd00fffff]
[KERNEL] [ 0.163339] pci_bus 0000:01: resource 2 [mem 0x1f700000-0x1f7fffff pref]
[KERNEL] [ 0.163344] pci_bus 0000:01: resource 4 [io 0x0000-0x0cf7]
[KERNEL] [ 0.163350] pci_bus 0000:01: resource 5 [io 0x0d00-0xffff]
[KERNEL] [ 0.163355] pci_bus 0000:01: resource 6 [mem 0x000a0000-0x000bffff]
[KERNEL] [ 0.163361] pci_bus 0000:01: resource 7 [mem 0x000c0000-0x000dffff]
[KERNEL] [ 0.163366] pci_bus 0000:01: resource 8 [mem 0x1f700000-0xfebfffff]
[KERNEL] [ 0.163442] NET: Registered protocol family 2
[KERNEL] [ 0.163982] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[KERNEL] [ 0.163982] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[KERNEL] [ 0.163982] TCP: Hash tables configured (established 4096 bind 4096)
[KERNEL] [ 0.163982] TCP: reno registered
[KERNEL] [ 0.163982] UDP hash table entries: 256 (order: 0, 4096 bytes)
[KERNEL] [ 0.163982] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[KERNEL] [ 0.164091] NET: Registered protocol family 1
[KERNEL] [ 0.164141] pci 0000:00:02.0: Boot video device
[KERNEL] [ 0.165982] PCI: CLS 0 bytes, default 64
[KERNEL] [ 0.166398] Trying to unpack rootfs image as initramfs...
[KERNEL] [ 0.174360] rootfs image is not initramfs (no cpio magic); looks like an initrd
[KERNEL] [ 0.184288] Freeing initrd memory: 3124K (df3b2000 - df6bf000)
[KERNEL] [ 0.186087] futex hash table entries: 256 (order: -1, 3072 bytes)
[KERNEL] [ 0.187218] ROMFS MTD (C) 2007 Red Hat, Inc.
[KERNEL] [ 0.187245] msgmni has been set to 984
[KERNEL] [ 0.187753] io scheduler noop registered
[KERNEL] [ 0.187773] io scheduler cfq registered (default)
[KERNEL] [ 0.188559] intel_idle: does not run on family 6 model 13
[KERNEL] [ 0.188905] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[KERNEL] [ 0.188924] ACPI: Power Button [PWRB]
[KERNEL] [ 0.189267] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[KERNEL] [ 0.189281] ACPI: Power Button [PWRF]
[KERNEL] [ 0.191144] brd: module loaded
[KERNEL] [ 0.191685] zram: Created 1 device(s) ...
[KERNEL] [ 0.191703] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[KERNEL] [ 0.191706] ehci-pci: EHCI PCI platform driver
[KERNEL] [ 0.192118] ehci-pci 0000:00:1d.7: EHCI Host Controller
[KERNEL] [ 0.192150] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[KERNEL] [ 0.196084] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[KERNEL] [ 0.196122] ehci-pci 0000:00:1d.7: irq 23, io mem 0xd01c0000
[KERNEL] [ 0.201833] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[KERNEL] [ 0.201955] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[KERNEL] [ 0.201965] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.201971] usb usb1: Product: EHCI Host Controller
[KERNEL] [ 0.201978] usb usb1: Manufacturer: Linux 3.14.48 ehci_hcd
[KERNEL] [ 0.201982] usb usb1: SerialNumber: 0000:00:1d.7
[KERNEL] [ 0.202588] hub 1-0:1.0: USB hub found
[KERNEL] [ 0.202631] hub 1-0:1.0: 8 ports detected
[KERNEL] [ 0.203161] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[KERNEL] [ 0.203170] ohci-pci: OHCI PCI platform driver
[KERNEL] [ 0.203357] uhci_hcd: USB Universal Host Controller Interface driver
[KERNEL] [ 0.203657] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[KERNEL] [ 0.203689] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[KERNEL] [ 0.203735] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000db00
[KERNEL] [ 0.203910] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.203922] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.203927] usb usb2: Product: UHCI Host Controller
[KERNEL] [ 0.203933] usb usb2: Manufacturer: Linux 3.14.48 uhci_hcd
[KERNEL] [ 0.203937] usb usb2: SerialNumber: 0000:00:1d.0
[KERNEL] [ 0.204591] hub 2-0:1.0: USB hub found
[KERNEL] [ 0.204639] hub 2-0:1.0: 2 ports detected
[KERNEL] [ 0.205131] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[KERNEL] [ 0.205162] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[KERNEL] [ 0.205215] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000dd00
[KERNEL] [ 0.205355] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.205364] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.205370] usb usb3: Product: UHCI Host Controller
[KERNEL] [ 0.205375] usb usb3: Manufacturer: Linux 3.14.48 uhci_hcd
[KERNEL] [ 0.205382] usb usb3: SerialNumber: 0000:00:1d.1
[KERNEL] [ 0.206072] hub 3-0:1.0: USB hub found
[KERNEL] [ 0.206118] hub 3-0:1.0: 2 ports detected
[KERNEL] [ 0.206569] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[KERNEL] [ 0.206600] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[KERNEL] [ 0.206661] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000d800
[KERNEL] [ 0.206791] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.206800] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.206805] usb usb4: Product: UHCI Host Controller
[KERNEL] [ 0.206810] usb usb4: Manufacturer: Linux 3.14.48 uhci_hcd
[KERNEL] [ 0.206861] usb usb4: SerialNumber: 0000:00:1d.2
[KERNEL] [ 0.207524] hub 4-0:1.0: USB hub found
[KERNEL] [ 0.207564] hub 4-0:1.0: 2 ports detected
[KERNEL] [ 0.208050] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[KERNEL] [ 0.208081] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[KERNEL] [ 0.208135] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000d900
[KERNEL] [ 0.208278] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.208287] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.208293] usb usb5: Product: UHCI Host Controller
[KERNEL] [ 0.208298] usb usb5: Manufacturer: Linux 3.14.48 uhci_hcd
[KERNEL] [ 0.208304] usb usb5: SerialNumber: 0000:00:1d.3
[KERNEL] [ 0.208980] hub 5-0:1.0: USB hub found
[KERNEL] [ 0.209020] hub 5-0:1.0: 2 ports detected
[KERNEL] [ 0.210318] i8042: PNP: No PS/2 controller found. Probing ports directly.
[KERNEL] [ 0.459868] serio: i8042 KBD port at 0x60,0x64 irq 1
[KERNEL] [ 0.460160] hv_vmbus: registering driver hyperv_keyboard
[KERNEL] [ 0.460517] mousedev: PS/2 mouse device common for all mice
[KERNEL] [ 0.461897] input: PC Speaker as /devices/platform/pcspkr/input/input3
[KERNEL] [ 0.462595] hidraw: raw HID events driver (C) Jiri Kosina
[KERNEL] [ 0.463980] hv_vmbus: registering driver hid_hyperv
[KERNEL] [ 0.466235] usbcore: registered new interface driver usbhid
[KERNEL] [ 0.466245] usbhid: USB HID core driver
[KERNEL] [ 0.466393] TCP: cubic registered
[KERNEL] [ 0.466402] NET: Registered protocol family 17
[KERNEL] [ 0.466508] Using IPI Shortcut mode
[KERNEL] [ 0.518292] RAMDISK: xz image found at block 0
[KERNEL] [ 0.918715] usb 4-1: new low-speed USB device number 2 using uhci_hcd
[KERNEL] [ 1.074786] usb 4-1: New USB device found, idVendor=192f, idProduct=0416
[KERNEL] [ 1.074796] usb 4-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[KERNEL] [ 1.074803] usb 4-1: Product: USB Optical Mouse
[KERNEL] [ 1.109702] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1d.2/usb4/4-1/4-1:1.0/0003:192F:0416.0001/input/input4
[KERNEL] [ 1.115764] hid-generic 0003:192F:0416.0001: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:00:1d.2-1/input0
[KERNEL] [ 1.185636] tsc: Refined TSC clocksource calibration: 997.499 MHz
[KERNEL] [ 1.185656] Switched to clocksource tsc
[KERNEL] [ 1.321623] usb 4-2: new low-speed USB device number 3 using uhci_hcd
[KERNEL] [ 1.485797] usb 4-2: New USB device found, idVendor=0461, idProduct=0010
[KERNEL] [ 1.485808] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[KERNEL] [ 1.485814] usb 4-2: Product: USB Keyboard
[KERNEL] [ 1.485820] usb 4-2: Manufacturer: NOVATEK
[KERNEL] [ 1.518373] input: NOVATEK USB Keyboard as /devices/pci0000:00/0000:00:1d.2/usb4/4-2/4-2:1.0/0003:0461:0010.0002/input/input5
[KERNEL] [ 1.522644] hid-generic 0003:0461:0010.0002: input,hidraw1: USB HID v1.10 Keyboard [NOVATEK USB Keyboard] on usb-0000:00:1d.2-2/input0
[KERNEL] [ 1.569600] input: NOVATEK USB Keyboard as /devices/pci0000:00/0000:00:1d.2/usb4/4-2/4-2:1.1/0003:0461:0010.0003/input/input6
[KERNEL] [ 1.570143] hid-generic 0003:0461:0010.0003: input,hidraw2: USB HID v1.10 Device [NOVATEK USB Keyboard] on usb-0000:00:1d.2-2/input1
[KERNEL] [ 1.885967] VFS: Mounted root (romfs filesystem) readonly on device 1:0.
[KERNEL] [ 1.886031] devtmpfs: mounted
[KERNEL] [ 1.886385] Freeing unused kernel memory: 316K (c051e000 - c056d000)
[KERNEL] [ 1.886548] Write protecting the kernel text: 3172k
[KERNEL] [ 1.886584] Write protecting the kernel read-only data: 832k
[pfac] Ok, PID 456.
[initrd] WTware shell v.5.2.38
[initrd] PCI: C 06 8086:2590 Bridge Intel Corporation Mobile 915GM/PM/GMS/910GML Express Processor to DRAM Controller.
[initrd] PCI: C 03 8086:2592 Display controller Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller.
[initrd] PCI: C 0c:03 8086:2658 Serial bus controller USB controller Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI.
[initrd] PCI: C 0c:03 8086:2659 Serial bus controller USB controller Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI.
[initrd] PCI: C 0c:03 8086:265a Serial bus controller USB controller Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI.
[initrd] PCI: C 0c:03 8086:265b Serial bus controller USB controller Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI.
[initrd] PCI: C 0c:03 8086:265c Serial bus controller USB controller Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller.
[initrd] PCI: C 06:04 8086:2448 Bridge PCI bridge Intel Corporation 82801 Mobile PCI Bridge.
[initrd] PCI: C 04:01 8086:266e Multimedia controller Multimedia audio controller Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) AC'97 Audio Controller.
[initrd] PCI: C 06:01 8086:2641 Bridge ISA bridge Intel Corporation 82801FBM (ICH6M) LPC Interface Bridge.
[initrd] PCI: C 01:01 8086:2653 Mass storage controller IDE interface Intel Corporation 82801FBM (ICH6M) SATA Controller.
[initrd] PCI: C 0c:05 8086:266a Serial bus controller SMBus Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) SMBus Controller.
[initrd] PCI: C 02 10ec:8139 Network controller Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter.
[initrd] USB: 192f:0416 Avago Technologies, Pte. ADNS-5700 Optical Mouse Controller (3-button).
[initrd] USB: 0461:0010 Primax Electronics, Ltd HP Keyboard.
[initrd] Load ethernet drivers.
[initrd] modprobe 8139too.
[KERNEL] [ 2.572353] 8139too: 8139too Fast Ethernet driver 0.9.28
[KERNEL] [ 2.577266] 8139too 0000:01:01.0 eth0: RealTek RTL8139 at 0x0001c000, 00:1a:a9:90:23:1f, IRQ 16
[KERNEL] [ 2.582077] 8139too 0000:01:02.0 eth1: RealTek RTL8139 at 0x0001c400, 00:1a:a9:90:23:20, IRQ 18
[initrd] NIC module 8139too.ko loaded.
[initrd] modprobe 8139cp.
[KERNEL] [ 2.592600] 8139cp: 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[initrd] NIC module 8139cp.ko loaded.
[initrd] eth0: 10ec:8139. Apply WOL configuration.
[KERNEL] [ 2.615427] 8139too 0000:01:01.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[KERNEL] [ 2.615671] 8139too 0000:01:02.0 eth1: link down
[initrd] dhcp: 369 bytes from 10.77.16.1.
[initrd] 00000000:0000015d00000000001100000a4d10010a4d100a00430044015d000002010600 ...]........M..M..C.D.]......
[initrd] 00000020:67458b6b00000000000000000a4d100a0a4d100c0a4d1001001aa990231f0000 gE.k.........M..M..M....#..
[initrd] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[initrd] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[initrd] dhcp: server address 10.77.1.15.
[initrd] dhcp: 10.77.16.10/255.255.255.192.
[initrd] dhcp: default gateway 10.77.16.1.
[initrd] dhcp: DNS 10.77.1.15.
[initrd] dhcp: DNS 10.77.1.14.
[initrd] dhcp: domain 7flowers.local.
[initrd] dhcp: TFTP 10.77.16.12.
[initrd] dhcp: boot file (067) 5.2.38/wtware.pxe.
[initrd] TFTP binary "5.2.38/", configs prefix "", using "/" slash.
Send broadcast WTCU discover.
[initrd] TFTP: download and unpack file 5.2.38/packages/lib6 from 10.77.16.12.
[initrd] WTware TFTP v.5.2.38.
[initrd] TFTP: download file Everyone/list.wtc from 10.77.16.12.
| # Nienie iiaee??aaiuo oaeeia.
| # Yoio ioaaeuiue iaoaieci iano?ieee oa?ieiaeia i?aaiacia?ai oieuei
| # aey ?o?iiai eiioeao?e?iaaiey oa?ieiaeia. A?aoe?aneee eiioeao?aoi?
| # ia ?eoaao list.wtc, ia ?eoaao e ia iicaieyao ?aaaeoe?iaaou oaeeu
| # ec eaoaeiaa ListIncludes. Iiyoiio iaeucy iuoaouny iano?aeaaou iaei
| # e oio ?a oa?ieiae e eiioeao?aoi?ii, e ?a?ac list.wtc.
| # Oi?iao no?iee a yoii oaeea:
| # 01.02.03.04.05.06[([eiyiieuciaaoaey@][eiyoa?ieiaea])] [oaee [oaee ...]]] [# eiiiaioa?ee]
| # I?eia?u:
| # 02.03.04.05.06.07 file1
| # Icia?aao, ?oi oa?ieiae n iae-aa?anii 02.03.04.05.06.07 i?i?eoaao
| # ia?aiao?u ec oaeea ListIncludes/file1.
| # Icia?aao, ?oi oa?ieiae n iae-aa?anii 03.04.05.06.07.08 i?i?eoaao
| # ia?aiao?u ec oaeea ListIncludes/file2 e a ieioei "Aoia a Windows"
| # iianoaaeo eiy iieuciaaoaey "vasja".
| # 04.05.06.07.08.09(term5) file6 file7 # Eiii caiaeaaaooa.
| # Icia?aao, ?oi oa?ieiaeo n iae-aa?anii 04.05.06.07.08.09 aoaao
| # i?enaiaii eiy term5, aiaeiae?ii oeacaie? ia?aiao?a clienthostname,
| # e ii i?i?eoaao ia?aiao?u ec oaeeia ListIncludes/file6 e
| # ListIncludes/file7.
| # ?oiau ii?ii auei oeacuaaou eiy iieuciaaoaey ?onneeie aoeaaie, iaai
| # ioe?uou yoio oaee a Notepad e nio?aieou n Encoding: Unicode.
[initrd] TFTP: download file Terminals/00.1A.A9.90.23.1F/config.wtc from 10.77.16.12.
| video=i915(F)
| bpp=16
| display=1600x900
| mouse_accel_mult=2
| server=SRVRDBCL
| user=7flowers\aabaev:\x61\x73\x62\x61\x6e\x38\x31\x4b\x39\x34
| domain=7flowers
| shell=
| directory=
| loadbalanceinfo=tsv://VMResource.1.VDI
| graphic=abcdefg
| language=ru,default
| smartcard=off
| clipboard=on
| turnoffmenu=poweroff
| connection
[initrd] TFTP: download file Everyone/all.wtc from 10.77.16.12.
| server=10.77.16.12
[initrd] TFTP: download file Everyone/wtware.lic from 10.77.16.12.
| [BOM]
| server=SRVRDBCL
| video=i915(F)
| bpp=16
| display=1600x900
| mouse_accel_mult=2
| domain=7flowers
| shell=
| directory=
| graphic=abcdefg
| language=ru,default
| smartcard=off
| clipboard=on
| connection
[initrd] Hostname: "wtw001AA990231F".
RSH: listener is active.
[initrd] TFTP: download and unpack file 5.2.38/packages/f from 10.77.16.12.
[KERNEL] [ 5.946663] random: nonblocking pool is initialized
[initrd] TFTP: download and unpack file 5.2.38/packages/fwt6 from 10.77.16.12.
[initrd] TFTP: download and unpack file 5.2.38/packages/graphic from 10.77.16.12.
[gm] WTware session manager v.5.2.38.
[gm] Load agpgart driver.
[gm] modprobe agpgart.
[gm] modprobe intel-agp.
[KERNEL] [ 6.533998] Linux agpgart interface v0.103
[KERNEL] [ 6.544626] agpgart-intel 0000:00:00.0: Intel 915GM Chipset
[KERNEL] [ 6.544670] agpgart-intel 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
[KERNEL] [ 6.544702] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[KERNEL] [ 6.546954] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xc0000000
[gm] Add keyboard event5: NOVATEK USB Keyboard.
[gm] Add keyboard event4: NOVATEK USB Keyboard.
[gm] EV_REL flag found. Add mouse event3: USB Optical Mouse.
[gm] Ignore event2: PC Speaker.
[gm] Add keyboard event1: Power Button.
[gm] Add keyboard event0: Power Button.
[gm] Display mode: 1600x900, 16 bit, 0 Hz, modeline "", DDC enabled, connector 0.
[gm] modprobe drm.
[KERNEL] [ 7.251152] [drm] Initialized drm 1.1.0 20060810
[gm] Run modprobe i915 modeset=1.
[gm] modprobe i915 modeset=1.
[KERNEL] [ 7.295208] [drm] Memory usable by graphics device = 256M
[KERNEL] [ 7.307024] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[KERNEL] [ 7.307039] [drm] Driver supports precise vblank timestamp query.
[KERNEL] [ 7.319954] [drm] initialized overlay support
[KERNEL] [ 7.515742] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[KERNEL] [ 7.515752] i915 0000:00:02.0: registered panic notifier
[KERNEL] [ 7.515777] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[gm] Kernel drm/kms module loaded.
[gm] count_fbs 0.
[gm] count_crtcs 2.
[gm] count_connectors 2.
[gm] count_encoders 2.
[gm] min_width 0, max_width 4096, min_height 0, max_height 4096.
[gm] ======================
[gm] connector_id 5.
[gm] encoder_id 6.
[gm] connector_type VGA (1).
[gm] connector_type_id 1.
[gm] connection 1.
[gm] mmWidth 440, mmHeight 250.
[gm] subpixel 0.
[gm] count_modes 19.
[gm] count_props 2.
[gm] count_encoders 1.
[gm] encoders_ptr [6]
[gm] connector_id 7.
[gm] encoder_id 0.
[gm] connector_type SVIDEO (6).
[gm] connection 2.
[gm] mmWidth 0, mmHeight 0.
[gm] subpixel 0.
[gm] count_modes 0.
[gm] count_props 7.
[gm] encoders_ptr [8]
[gm] crtc_id 3.
[gm] fb buffer_id 0 (disconnected from fb).
[gm] x 0, y 0.
[gm] mode_valid 1.
[gm] Mode : clock 0 H 0 0 0 0 0 V 0 0 0 0 0 VR 0 flags 0x0000 type 0x0000.
[gm] gamma_size 256.
[gm] 0 connectors.
[gm] crtc_id 4.
[gm] x 0, y 0.
[gm] mode_valid 0.
[gm] 0 connectors.
[gm] encoder_id 6.
[gm] encoder_type DAC (1).
[gm] crtc_id 3.
[gm] possible_crtcs 7.
[gm] possible_clones 1.
[gm] encoder_id 8.
[gm] encoder_type TVDAC (4).
[gm] crtc_id 0.
[gm] possible_crtcs 3.
[gm] possible_clones 2.
[gm] Connector Id 5.
[gm] Encoder Id 6.
[gm] CRTC Id 3.
[gm] Force 60Hz refresh.
[gm] Mode 1600x900: clock 108000 H 1600 1624 1704 1800 0 V 900 901 904 1000 0 VR 60 flags 0x0005 type 0x0048.
[gm] ^^^ Use this mode ^^^.
[gm] Mode 1440x900: clock 136750 H 1440 1536 1688 1936 0 V 900 903 909 942 0 VR 75 flags 0x0006 type 0x0040.
[gm] Mode 1440x900: clock 106500 H 1440 1520 1672 1904 0 V 900 903 909 934 0 VR 60 flags 0x0006 type 0x0040.
[gm] Mode 1280x800: clock 83500 H 1280 1352 1480 1680 0 V 800 803 809 831 0 VR 60 flags 0x0009 type 0x0040.
[gm] Mode 1152x864: clock 108000 H 1152 1216 1344 1600 0 V 864 865 868 900 0 VR 75 flags 0x0005 type 0x0040.
[gm] Mode 1280x720: clock 74440 H 1280 1336 1472 1664 0 V 720 721 724 746 0 VR 60 flags 0x0006 type 0x0000.
[gm] Mode 1024x768: clock 78800 H 1024 1040 1136 1312 0 V 768 769 772 800 0 VR 75 flags 0x0005 type 0x0040.
[gm] Mode 1024x768: clock 75000 H 1024 1048 1184 1328 0 V 768 771 777 806 0 VR 70 flags 0x000a type 0x0040.
[gm] Mode 1024x768: clock 65000 H 1024 1048 1184 1344 0 V 768 771 777 806 0 VR 60 flags 0x000a type 0x0040.
[gm] Mode 832x624: clock 57284 H 832 864 928 1152 0 V 624 625 628 667 0 VR 75 flags 0x000a type 0x0040.
[gm] Mode 800x600: clock 49500 H 800 816 896 1056 0 V 600 601 604 625 0 VR 75 flags 0x0005 type 0x0040.
[gm] Mode 800x600: clock 50000 H 800 856 976 1040 0 V 600 637 643 666 0 VR 72 flags 0x0005 type 0x0040.
[gm] Mode 800x600: clock 40000 H 800 840 968 1056 0 V 600 601 605 628 0 VR 60 flags 0x0005 type 0x0040.
[gm] Mode 800x600: clock 36000 H 800 824 896 1024 0 V 600 601 603 625 0 VR 56 flags 0x0005 type 0x0040.
[gm] Mode 640x480: clock 31500 H 640 656 720 840 0 V 480 481 484 500 0 VR 75 flags 0x000a type 0x0040.
[gm] Mode 640x480: clock 31500 H 640 664 704 832 0 V 480 489 491 520 0 VR 73 flags 0x000a type 0x0040.
[gm] Mode 640x480: clock 30240 H 640 704 768 864 0 V 480 483 486 525 0 VR 67 flags 0x000a type 0x0040.
[gm] Mode 640x480: clock 25200 H 640 656 752 800 0 V 480 490 492 525 0 VR 60 flags 0x000a type 0x0040.
[gm] Mode 720x400: clock 28320 H 720 738 846 900 0 V 400 412 414 449 0 VR 70 flags 0x0006 type 0x0040.
[gm] Once more, choose this mode:
[gm] fb_ptr 0xb72c0000
[gm] stride 3200.
[gm] size 2880000.
[gm] handle 0x00000001.
[gm] fb_id 0.
[gm] width 1600.
[gm] height 900.
[gm] pitch 3200.
[gm] bpp 16.
[gm] depth 16.
[gm] LINELENBYTES 3200, VBUF 0x0xb72c0000.
[gm] WMEMCOPY: 27000K copied in 0.050221 sec.
[gm] libc: 27000K copied in 0.044130 sec.
[gm] movs: 27000K copied in 0.043089 sec.
[gm] MMX: 27000K copied in 0.041471 sec.
[gm] SSE2: 27000K copied in 0.041684 sec.
[gm] Choose MMX memcpy.
[pfac] Got command line /sbin/resolver 0x8905ec0 dns [SRVRDBCL].
[pfac] Ok, PID 514.
[gm] Nobody can control terminal by VNC.
[gm] SRVRDBCL => 10.77.165.19.
[gm] SRVRDBCL => 10.77.165.20.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 1): 482792 Kb.
[pfac] Ok, PID 515.
[pfac] Process pid 514 terminated, status 00000000.
[rdpclient 515] RDP Terminal Client, WTware v.5.2.38, pipe 1, pid 515.
[rdpclient 515] Make RDP session with 10.77.165.19, 10.77.165.20, port 3389.
[rdpclient 515] Username: "aabaev".
[rdpclient 515] Password: present.
[rdpclient 515] No PIN.
[rdpclient 515] Domain: "7flowers".
[rdpclient 515] No shell.
[rdpclient 515] No directory.
[rdpclient 515] Window: 1536x900@16.
[rdpclient 515] PFlags 0x00000180.
[rdpclient 515] Keyboard 00000409:00000000.
[rdpclient 515] My hostname "wtw001AA990231F".
[rdpclient 515] TCP: connection with 10.77.165.19:3389 established.
[rdpclient 515] Turn keepalive on.
[rdpclient 515] Free ram after buffers allocation: 479568 KB.
[rdpclient 515] Use Balance Info 22 bytes: 'tsv://VMResource.1.VDI'.
[rdpclient 515] Reconnect with CredSSP enabled.
[rdpclient 515] TCP: reconnecting to 10.77.165.19:3389.
[rdpclient 515] Close TCP connection while receiving data, errno 104.
[rdpclient 515] rdpclient-connect.cpp ( 417): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 515] rdpclient-connect.cpp ( 2341): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 515] rdpclient-connect.cpp ( 2574): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 515] TCP/IP connection lost. Network failure?
[rdpclient 515] Caught signal SIGTERM.
[pfac] Process pid 515 terminated, status 00000000.
[gm] Final message: TCP/IP connection lost. Network failure?
[gm] /graphic/exlm.png: 44x42.
Home WTware diskless client.
Ошибка при подключении к брокеру INTERNAL ERROR
Re: Ошибка при подключении к брокеру INTERNAL ERROR
Ничего по существу не могу сказать. Я слишком плохо разбираюсь в майкрософтовых фермах, и мне ещё ни разу не показывали две одинаковые фермы, они почему-то всегда разные получаются, с разными капризами
Насколько я помню, если в конфиге указано правильное заклинание в loadbalanceinfo, то в реестр ничего писать не надо. Брокер по этому заклинанию должен сам определить, куда ему послать терминал.
Ещё вижу в логе включенный NLA. Попробуй его выключить, вдруг поможет. Выключить везде: и на брокере, и на самих серверах. http://wtware.ru/win/nla.html
Совсем бестолковая ошибка. Сервер разорвал соединение безо всяких комментариев. Иногда в логах сервера (Event View) что-то интересное может быть, и я не смогу толком объяснить, что именно надо искать, надо искать записи по точному времени когда терминал отвалился. Иногда в логах сервера пусто.Александр А. писал(а):[rdpclient 515] Close TCP connection while receiving data, errno 104.
Я тут сам затупил. Убрал из конфига loadbalanceinfo - оно же в реестре есть и все полетело!
